Adhesive Cable Tie 20x20mm White (Set x50)
These adhesive cable ties simply attach to a wall to allow you to group your cables together. The base of the cable ties is adhesive and can be easily attached to any surface. Two holes allow you to screw the clips for a firmer hold.
Reference : 15345
5,90 €tax incl.
4,92 € tax excl.
Shipping date: 20-05-2025.
Cable ties
Adhesive Cable Ties 20x20mm White (Set x50)
Attache Câble Adhésif 20x20mm Blanc
Cable ties, sold separately (see accessories), are required to attach your cables. This product is the base of the attachment system.
Product typeCable tie
Dimensions20 x 20 x 7mm
Adhesive
Fixation holes spacing14mm
Dimensions of hose clamp mounting space5 x 2.5mm
ColorWhite
Quantityx50
Material
  • Plastic
Length (m)
  • Sold by length
Section (mm²)
  • N/A
Conductors material (Cable)
  • N/A
These adhesive cable ties simply attach to a wall to allow you to group your cables together. The base of the cable ties is adhesive and can be...
