Adhesive Cable Ties (Set x10)
These adhesive cable holders will solve all your problems with tangled or trailing cables. The pack consists of a total of 10 brackets.
Reference : 16193
3,90 €tax incl.
3,25 € tax excl.
Shipping date: 25-04-2025.
Adhesive Cable Ties
(Set x10)
Fixations Adhésives pour câbles (set x10)
These adhesive cable holders will solve all your problems with tangled or trailing cables. The pack consists of a total of 10 brackets: 2 with 6 slots for cables up to approx. 10mm in diameter, 2 with 3 slots for cables up to 9mm in diameter and finally 6 brackets with a single slot for cables up to 6mm in diameter. Mounting is as simple as gluing the brackets to a flat surface using the adhesive provided.
Product typeCable ties
Composition of the pack2x 6-slot holders (dimensions : 86x19x13mm) - Max cables diameter : 10mm
2x 3-slot holders (dimensions : 53x16x14mm) - Max cables diameter : 9mm
6x 1-slot holders (dimensions : 17x12x12mm) - Max cables diameter : 6mm
MountingAdhesive
