FURUTECH Nano Liquid Gold + Silver Squalene Oil
4.0 / 5
Reference : 2591
179,00 €tax incl.
149,17 € tax excl.
Shipping date: 06-05-2025.
Liquid Nano improves contacts, restores old connections and improves the recent ones.
The molecules of this incredible nano liquid are so tiny that they "fill" all the holes present on the contact to be improved.
TheThe result is a much better contact between the surfaces.
Thee Nano Liquide is the result of a search by Furutech for each aspect of signal transmission.
To be used only in small quantities!
This product is made up of micro-particles (thanks to nanotechnology) Goldenandof pure silver.
The maximum particle diameter is 8 nanometers (8 / 1,000,000mm).
Operation:
The can contains squalene oil which eliminates the oxide present on metal surfaces because squalene has the property of absorbing oxygen.
UOnce the contact is cleaned of any pollution, the microparticles of silver and gold will be fixed in the pores present on the surface of the contact.
Inthus increasing the electrical signal and lowering the impedance.
Improvements:
audio:
An overall improvement in sound, high, medium and low frequencies.
Volume, echo, extension, penetration, resolution, and sense of form are exceptionally better rendered.
video :
Improves the resosharpness, color, brightness, image depth and graphics quality.
power :
Increases contact area and improves conductivity.
Reduces heat generated by contacts, saves energy and reduces micro breaks.
Eliminates the oxidation phenomenon and increases the lifetime of the product, avoids all sparks
renfothe effect of cleanliness, protection and lubrication of the contact surface./ P>
Use :
Audio / Video equipment: RCA, speaker terminal, CD / VCD / DVD / MD / TV / etc ...
All electronic and electrical products: battery connection point, AC outlet.
Also used in machine tools, all kinds of motor coals, measurement, communication and medical instruments.
Length (m)
  • Sold by length
Section (mm²)
  • N/A
Conductors material (Cable)
  • N/A
9 reviews
potion magique!
Bonsoir , j ai testé le Nano liquide or , sur ma tv et blu ray via hdmi et cables secteurs : résultat ,meilleur contratse, fluidité, luminosité, ,profondeur d image . Pour le son ,nano sur usb ,cable secteur, ipurifier ifi : résultat des basses plus rapides ,plus serrées, une meilleure transparence, des iagus plus doux, dynamique générale,plus de finesse. J ai amélioré mon dac et ma platine cd . Je recommande ce produit malgré un prix élevé!!!!!
This review has been posted for FURUTECH Nano Liquid Gold + Silver Squalene Oil
Juste excellent
J’ai je pense un système haut de gamme déjà très optimisé.
Au vu du prix du produit j’en ai retardé l’essai .
J’ai finalement acheté ce produit et j’ai pour l’instant traité les câbles hp au niveau de l’ampli et des enceintes . Le résultat est spectaculaire . Un gain net et évident en dynamique, qualité du grave scène stéréo et a un moindre degré un peu plus de transparence .
Si vous avez un sytème haut de gamme , il n’y a aucune hésitation . Foncez sur ce Furutech nano
liquid liquid
pour être convaincu je l'ai utilisé sur les contacts de mon chargeur iphone et quand je l'utilise en le branchant j'ai une vitesse de réponse assez étonnante...amazing...
fiole magique !
Ce précieux "élixir" pour contacts rend la restitution plus naturelle. On entend tout mieux, tout simplement. Le son est plus riche : plus de matière, plus d'aération, plus de précision dans l'image stéréophonique, les petits détails qu'on entendait pas ou peu deviennent évidents mais sans "effet loupe". C'est particulièrement évident sur les voix. Certes, le prix est élevé mais on en utilise très peu à chaque traitement.
Il y a du requin dans les contacts
Je pourrai écrire 10 pages sur ce produit que j'ai expérimenté et je fais faire court dans cet avis. Non, ce n'est pas une arnaque, ça fonctionne surtout sur les contacts faible tension, modulation ou phono, sortie de DAC et entre préampli et ampli. Le résultat se fait entendre au bout de 48 heures et ce sera patent si la chaîne est résolvante. Sinon rien. Dans le meilleur des cas, on entend des choses comme d'avantage de résolution, d'air, et une différence très marquée entre différentes sources. C'est à dire que les meilleurs enregistrements seront fantastiques et les mauvais inaudibles. En faisant remonter le médium aigue des enregistrements durs par exemple. Débat : ce produit augmente t-il la tendance d'un système ? Nous ne sommes pas d'accord entre audiophiles, physiciens de notre petite communauté. Est-ce par exemple l'effet de peau qui se fait sentir ici en favorisant la définition des fréquences aigues ? A essayer si votre système est transparent mais à dose homéopathique. Pour moi, je valide même à 120.000 euros le litre ! Mon système : CD Wadia - DAC 2X Emmlabs - Platine Goldmund - préampli et ampli CELLO - Enceintes Prodigy Martin Logan - Câbles Legato, barrette WhyNot... on entend TOUT.
