VIABLUE NF-AIR Reducer 18mm to 11mm
This Viablue NF-AIR reducer is ideal for clean cable assembly. The inlet diameter is Ø18mm and the outlet diameter is Ø11mm. The cable is held in place with M4 screws
Reference : 8630
19,40 €tax incl.
16,17 € tax excl.
Shipping date: 16-04-2025.
Viablue NF-AIR
Viablue NF-AIR Réducteur 1x9.5mm vers 2x8mm
This Viablue NF-AIR reducer is ideal for clean cable assembly. The inlet diameter is Ø18mm and the outlet diameter is Ø11mm. The cable is held in place with M4 screws. It is recommended to use in addition to the heat shrink tubing (sold separately) for a perfect finish.
Product typeReducer
Length45mm
External diameterØ27mm
Input diameterØ18mm
Output diameterØ11mm
Compatible Viablue CableNF-S6 Air Silver
Length (m)Sold by length
Section (mm²)N/A
Conductors material (Cable)N/A
This Viablue NF-AIR reducer is ideal for clean cable assembly. The inlet diameter is Ø18mm and the outlet diameter is Ø11mm....
