Section (mm²)
0 mm - 15 mm
Diameter (mm)
Conductors material (Cable)
Conductors Plating (Cable)
Number of conductors
Insulation material
Ground / Shielding
Shielding
Didier T.
Un très grand cru !
Intercalé entre ma Box et mon Node 2i, de dernier injecte son stream dans un Nuprime Dac 9SE amplifié par un bloc stéréo...
Christoph S.
Surprisingly good
Drives my loudspeakers with ease and precision. Better than expected experience.
Alessandro C.
IAN CANADA PUREPI
Incredible power system for Raspberry PI and for ES9038 + FIFO Q7 II. Allows you to obtain a very clean power supply. Great...
Bulk Cables
  • Speaker Cables
    Speaker Cables
    Find here all our cables for speakers and loudspeakers, sold by the meter, cut, allowing the design of your own finished cables.
  • Interconnect Cables
    Interconnect Cables
    Find here all our modulation cables, sold by meter, cut, allowing the design of your own finished cables.
  • Digital Cables
    Digital Cables
    Find here all our digital cables, sold by the meter, cut, allowing the design of your own finished cables.
  • Power Cables
    Power Cables
    Find here all our power cables, sold by the meter, cut, allowing the design of your own finished cables.
  • Hook-up Wires
    Hook-up Wires
    Find here all our wiring wires, sold by the meter, to cut, allowing the internal wiring of your devices and DIY projects.
  • Silver Gold Copper Wires
    Silver wire, OCC wire
  • Wiring Accessories
    Wiring Accessories
