AUDIOPHONICS TORNADO Power Cable OFC Copper Double Shielded 3x4mm² Ø 12.9mm
WM-Audio TORNADO Power Cable Double Shield 3x4mm² Ø 12.9mm
This 3x4mm² Audiophonics Tornado cable features OFC copper conductors for enhanced conductivity. It also features double shielding against EMI/RFI interference.
4.8 / 5
Reference : 3297
9,90 €tax incl.
8,25 € tax excl.
Câble vendu au mètre
Photo of Audiophonics Tornado power cable
This 3x4mm² Audiophonics Tornado cable features OFC copper conductors for enhanced conductivity. It also features double shielding against EMI/RFI interference, consisting of metal foil and copper braid. This cable guarantees clean, stable power supply to your devices.
Product typeMains power cable
Conductor materialOFC copper
ShieldingMetal foil + Copper braid
CFros-section3x4mm²
External diameter12.9mm
External sheathPVC
PackageSold by meter
Diameter (mm)12.9
Length (m)Sold by length
Number of conductors3
Insulation materialNC
ShieldingYes
Section (mm²)4.00
ConnectorN/A
Ground / ShieldingYes
23 reviews
Buy and wait for ugly burn-in...you will be more than satisfied.
I mounted the cable to cheap plastic plugs (EU Power Plug 12 euros for 2) 2x1.5m
After 2 weeks of constant burn in I connected the 2 cables to 2 sbooster power supplies to my chord qutest and Auralic Aries
The sound is warmer with a good base foundation without losing resolution, more organic mid-range and the most important: !!! extremely musical and natural sound with a good size of the sound image.
I compared with transparent power cord 500 euros and up and I was not disappointed.
This review has been posted for AUDIOPHONICS TORNADO Power Cable OFC Copper Double Shielded 3x4mm² Ø 12.9mm
Tornado blows expensive ones
Second time purchase this product, first time implementation was in system for 100000Euro the result was amazing, more definition,better separation and wider sound scene(replacement was only for monoblocks).Now expect delivery from Audiophonics to implement on system for 500000Euro and above for all sources, pre amp,phono and monoblocks.For those who are sceptical about power cords, pleace try and then share the experience .Also on system let me say" low quality "it doesn't matter what kind of power cable you are using .
On the second system I and my friend who is the owner started with replacing power cords of Halcro dm10 pre and Halcro dm58 monos, just for the experiment .Amazing result,he confirm that this replacement change the sound entirely with the same performance as in my first atempt.
As soon as I finish with the project, I will post results!
Thanks again Audiophonics!
Neutre et serein
Cela fait huit ans que j'alimente mon ampli principal avec ce câble, je pense avoir assez de recul pour en dire tout le bien que j'en pense. Image sonore élargie et qui respire. Câble ayant la faculté première de supprimer les agressivités surtout dans les aigus. J'ai pu reconfirmer ce dernier point avec la confection d'un second câble pour mon préampli phono. Une fois ce dernier installé, et avec peu de rodage, la différence est évidente. Tout est plus posé, équilibré et tend vers une certaine neutralité. Un des meilleurs rapport qualité-prix à ma connaissance.
 (4)
Rapport qualité prix imbattable
Ce câble m’ a permis d’alimenter mes deux belles cabasse The Pearl qui avait un câble d’origine simple.
Il amène une grosse ouverture de scène et supprime ce voile que possèdent ces deux enceintes.
Très bon rapport qualité prix. Mais attention la première écoute est raide, quelques heures sont nécessaire afin de livrer la totalité du spectre équilibré.
Coupler à deux prises iec et schuco Elec audio amène deux câbles secteurs abordable
Câble un peu rigide, en prenant son temps nous arrivons à bon résultat d’assemblage.
 (3)
Mon scepticisme à l'égard de l'utilité de soigner la liaison électrique entre la prise 220V du mur et l'ampli était grand avant que je jette mon dévolu sur le WM audio Tornado. Ce câble imposant et rigide a indiscutablement augmenté le dynamisme et l'aération de la restitution. A l'écoute, la distance entre les enceintes est accentuée et gratifiée d'un effet surround (la profondeur spécifique à ce câble dont parle Raphael S.).
Un peu comme si des haut-parleurs supplémentaires avaient trouvés place sur les côté extérieur des enceintes. Le son semble par moment venir également de la pièce d'à côté.
Le rendu stéréo est bluffant.
Donc oui ! Loin des polémiques qui tentent de discréditer l'importance de la qualité des cordons d'alimentation, une écoute objective impose de reconnaitre que ce paramètre influe sur le résultat avec force.
Faites-en l'expérience
 (4)
This 3x4mm² Audiophonics Tornado cable features OFC copper conductors for enhanced conductivity. It also features double shielding against...
