ELECAUDIO CS-321B Power Cable OCC PTFE 3x2.5mm² Double shielding Ø12mm
4.6 / 5
Reference : 5258
14,90 €tax incl.
12,42 € tax excl.
Shipping date: 10-04-2025.
Thanks to its expertise in the production of customized audio / video cables, the ELECAUDIO team has devised a mains cable capable of satisfying your needs and desires at an affordable price, while guaranteeing the expected results thanks to the latest materials and technologies.
The Phase and Neutral (Black and White) of the CS-321B are each made up of:6 DECO deoxygenated copper strands of 0.10mm diameter, more 1 strand OCCof 0.12mm in diameter, or one section of 2.5mm² per conductor .
Is the Earth (green) composed of 6 DECO deoxygenated copper strands of 0.10mm in diameter, plus OFC of 0.12mm diameter. Sor a section of 2.5mm² for this driver as well.
ELECAUDIO CS-321B OCC Câble Secteur OCC FEP 3x2.5mm² Ø 12mm
These 3 conductors with a very sharp structure are encapsulated individuallyin PVC + FEP jackets marked with a color code :Black / White / Green. The three beams thus formed are themselves isolated from each other and kept in a distant order by means of a padding in cotton which provides flexibility and firmness to the cable.
A double insulation made of FEP insulation and a PVC sheath, concludes this cable and finishes making the CS-321B particularly resistant to the harshness of the outside world while giving it a unique design thanks to its night blue color which brings a touch of class and sobriety.
Features:
  • Phase and Neutral Conductors (Black and White): 1x26x0.12mmOCC+ 6x38x0.10 OFC,section of 2.5mm² each
  • Ground conductor (green): 1x26x0.12mmOFC+ 6x38x0.10 OFC,section of 2.5mm² also
  • Paddingcotton
  • armouringMylar
  • Shielding Drain: 26 x 0.16mm
  • Shielding braid:OFC Copper
  • Double insulation: Insulation winding PTFE+ sheathPVC
  • Total cable diameter: 12 mm
  • Bending radius: ~ 6cm
  • Color: dark blue
Diameter (mm)12.0
Length (m)Sold by length
Number of conductors3
Insulation materialPTFE
ShieldingYes
Section (mm²)2.5
ConnectorN/A
Ground / ShieldingYes
28 reviews
increased headphone system
i used this cable before my power strip, and it helped me increase my headphone sound quality (after titanex power cable).
Thanks.
This review has been posted for ELECAUDIO CS-321B Power Cable OCC PTFE 3x2.5mm² Double shielding Ø12mm
Good performances
I tried Elecaudio CS 321B on my CD reader and the result was definitely better than the CS 331B I used till now. So I decided to try it also on my ampli.
Audiophonics service is precise and on time as usual
Câble elec audio
Super produit a pas cher pour ma barrette, en association avec les prises furutech. Le câble est très bon en son si il y a des prises de qualité,, comme pour tout câble de toute façon.
Compared this cable with the stock cable that goes with Marantz PM-8006 and instantly heard tighter bass. No soldering. Connectors are also Elecaudio.
Iscott
Câble très bien construit et il agit sur la musicalité et la différence est audible de suite par rapport aux autres câbles mais la restitution est très douce et feutrée manque de dynamique a marier avec des électroniques agressives .
Cordialement
