ELECAUDIO CS-331TPE Power cable IN WALL TPE OFC Copper 3x3.5mm² Ø12mm
4.3 / 5
Reference : 12203
11,90 €tax incl.
9,92 € tax excl.
Shipping date: 15-04-2025.
With its expertise in custom audio / video cables and the success of its CS-331B mains cable, ELECAUDIOimagined a mains cable "IN WALL"specially adapted for walls. Indeed, you can pass this CS-331TPE cable through your walls thanks to its relatively small diameter (Ø12mm) and especially its sheath made of resistant TPE at high temperatures, while maintaining electrical and sound properties and performance.
Thus each driver of the CS-331TPE consists of 7 strands of 10 strands of deoxygenated copper OFC of each 0.25mm in diameter, ie a section of 3.5mm² per conductor .
These 3 conductors with the highly studied structure are encapsulated individually in PVC sheaths marked with acolor code Yellow / Blue / Brown. The three beams thus formed are themselves isolated from each other and held in a distant order by means of a cotton garniturewhich provides both flexibility and firmness to the whole.
Then there is a shielding made from a aluminum strip. Alongside this line of defense slips an OFC copper drain wirethe cable from one end to the other to ensure a linear earthing , synonymous with enhanced protection against radio interference(RFI) andelectromagnetic (EMI).
A protective sheath in TPE of 1mm thickness completes this work, and finishes making the CS-331TPE particularly resistant to the harshness that can be found in walls and extreme temperatures.
This cable which uses a TPE sheath meets the standards for fixed installations, in case of fire this material is flame retardant, low smoke emission and halogen-free.
Features:
  • Special wall cable: IN WALL
  • 3 OFC Copper Conductorsof each one3.50mm² of Section
  • Double Shielding and Protection:OFC Aluminum Sheet + Copper Drain
  • Outer TPE Tubing (1mm): high temperature resistance
  • Trim inCotton
  • High-End Finish
Specifications:
  • Individual Driver Composition:7 x 10 0.25mm OFC Copper Wire of Diameter
  • Composition of the Shielding Sheath:24 x 9 Copper Wires 0.12mm Diameter Braid
  • Diameter of Conductors + Single PVC Sheath:4.30mm
  • Total Cable Diametere: Ø 12 mm
  • Color Black
Cable schematics
Schéma câblage câble secteur
Diameter (mm)12.0
Length (m)Sold by length
Number of conductors3
Insulation materialTPE
ShieldingYes
Section (mm²)3.50
ConnectorN/A
Ground / ShieldingYes
6 reviews
Good for custom installation
A bit fat but it is good cable for custom interwall instalation for example a dedicated line
This review has been posted for ELECAUDIO CS-331TPE Power cable IN WALL TPE OFC Copper 3x3.5mm² Ø12mm
Ligne directe
Utilisé pour tirer une ligne directe (prévu pour ça) pour mon installation avec son propre disjoncteur. Avant d'investir dans des câbles HP ou RCA HDG, commencez par ça, vous serez surpris ! J'ai même réussi à motiver un acheteur qui a une bonne installation de faire de même !
Perfect cable for installation
This is a perfect cable for 230 voltage to your stereo. You can win lot's of dynamics and nice mids and highs. Unbelievable what this cable does.
delif
Acheté pour alimenter mes amplificateurs Jadis JA 200
Câble Secteur de bonne fabrication, résistant et assez souple pour son diamètre, pas difficile à monter à condition de bien dégager les fils d’alimentation de la garniture en coton et du fil de drain.
Assez mélodieux, pas de dureté, médium aigu un peu descendant, grave ample mais sans excès, spatialisation et dynamique moyenne. Globalement la reproduction est un peu triste, sonne mate et manque, de respiration.
Ce câble peut aller sur des électroniques avec une prédominance du médium, haut-medium, aigu, mais ne convient pas sur mon système.
Excellent câble
J'avais besoin de puissance. Les 3x3,5mm² font merveille.
Je l'ai habillé d'une gaine nylon pour faire joli.
D'un cote, j'ai mis une prise Schuko PS-24GB, faite pour les grosse puissance- et de l'autre un presse étoupe RA-01B qui se met en lieu et place d'une prise IEC (même entraxe de fixation). Ca donne une ligne d'alimentation avec une capacité en courant énorme. Pas de problème pour les gros appels de courant.
