FURUTECH FP-3TS20 Power cable OCC Copper (Alpha) Ø14.3mm
4.6 / 5
By buying this product you get 30 loyalty points
Reference : 4889
109,00 €tax incl.
90,83 € tax excl.
Shipping date: 16-04-2025.
The FP-3TS20 is a very high-performance 3-wire power cable dedicated to uncompromising audio applications. The FP-3TS20 demonstrates manufacturing quality and technicality that leaves no doubt as to its top-of-the-range positioning.
Thus, each conductor is made up of a central core consisting of 56 single crystalline OCC copper strands, each 0.18mm in diameter, surrounded at its periphery by 29 strands of the same composition, i. e. a total cross-section of 2.16mm² per conductor.
Each of these bundles is individually insulated within a 3.53mm diameter polyethylene sheath covered with a teflon film, while the whole is then protected by a double protection with PVC inner sheath and braided copper shielding.
As is customary with this manufacturer, all metals will have benefited from the proprietary Alpha? anti-magnetism process, which involves 2 steps:
1- Cryogenisation of metals by -250°C using liquid nitrogen in order to consolidate their molecular structure and significantly improve their conductivity.
2- Submission of these same metals to a powerful magnetic field created by means of magnets arranged in rings, and whose attraction force is constantly controlled in order to leave no magnetic residue at the end of the treatment.
This second technique, developed in collaboration with the Japanese firm SEKIGUCHI MACHINE SALES, takes part in making FURUTECH cables exceptional conveyors for any electrical signal invested in sound reproduction.
Specifications:
  • Power cable 3 conductors Very High Performance
  • 3 Conductors of Unit Section 2.16mm² Consisting of a total of 85 Copper? -OCC (Alpha) Strands of each 0.18mm Diameter
  • 3.53mm Diameter Polyethylene Insulation Covered with Teflon Film and Colour coded (Red / White / Yellow)
  • 9.6mm Diameter High Flexibility Black PVC Inner Sheathing 9.6mm Diameter
  • Braided shielding made of 9 x 24 copper wire? -OFC (Alpha) of 0.12mm diameter.
  • Exterior shell in ultra-high-strength Night Blue PVC (Dark Blue)
  • Maximum Conductor Resistance: 0.008? / M
  • Total Cable Diameter: 14.3mm
  • Colour code: Red=Phase / Yellow=Neutral / White=Earth
https://www.audiophonics.fr/images2/4889_FURUTECH_FP-3TS20_5.jpg
https://www.audiophonics.fr/images2/4889_FURUTECH_FP-3TS20_1.jpg
https://www.audiophonics.fr/images2/4889_FURUTECH_FP-3TS20_2.jpg
https://www.audiophonics.fr/images2/4889_FURUTECH_FP-3TS20_3.jpg
https://www.audiophonics.fr/images2/4889_FURUTECH_FP-3TS20_6.jpg
https://www.audiophonics.fr/images2/4889_FURUTECH_FP-3TS20_4.jpg
https://www.audiophonics.fr/images2/4889_FURUTECH_FP-3TS20_7.jpg
Diameter (mm)14.3
Length (m)Sold by length
Number of conductors3
Insulation materialOther
ShieldingYes
Section (mm²)2.16
ConnectorN/A
Ground / ShieldingYes
14 reviews
Bon cable
Utilisé avec un dac préampli, il est a sa place.
Spzcialisation, scène sonore large et bien défini. Détail mais reste plus chaud que je l' aurai pensé, d' après les commentaires. Je recommande
This review has been posted for FURUTECH FP-3TS20 Power cable OCC Copper (Alpha) Ø14.3mm
Validé !
Bon rapport qualité prix. Je rejoins les divers commentaires.
Bien mieux sur les sources . Branché sur le Dac audio gd r1 un trés joli mariage : Musical et détaillé.
Attention aux codes couleurs. Jaune pour neutre .
Qualité d'image nette
Achetez ce câble avec les connecteurs Furutech FI-8.1 NCF et FI-E50 NCF (R) pour connecter un téléviseur Samsung 4K.
J'ai opté pour cet OCC car à mon avis il est plus vierge dans la transmission de l'énergie électrique par rapport à un U-OFC du même prix.
Dès que j'ai allumé l'écran, j'ai été surpris par la clarté accrue de l'écran, avec quelques images de référence, j'ai pu apprécier ce que faisait cet ensemble:
L'aspect d'écran sale a disparu presque complètement. Appréciez les nuances de couleurs dégradées que je ne connaissais pas, les couleurs sont vibrantes, saturées et à un niveau authentiquement différent et très similaire à la vie réelle, certains semblent regarder une fenêtre et non un écran comme avant d'installer ce câble et son jeu de connecteurs. Les ombres et les images dans l'obscurité sont apparues pour laisser place à un fond noir qui a donné lieu à plus d'informations et de détails. Dans les images en mouvement et dans la transition, par exemple, des onglets d'ouverture et de fermeture dans Windows, la réponse en millisecondes montre qu'elle a été raccourcie pour donner des images plus douces et plus précises dans son mouvement. Le son est un autre grand effet évidemment affecté, pouvant augmenter plus de points de volume que la quantité normale que j'utilisais, avec un son avec beaucoup de corps et de détails, et une scène sonore accrue dans toutes les directions à la fois en largeur, hauteur, profondeur en avant et en arrière, Tous très bien contrôlés. Tout cela au cours de la première semaine de tournage, par expérience, je sais que ces Furutech OCC gagnent en qualité avec le temps.
Excellent rendu
Je retrouve tous les caractéres décrits par Sylvain D le 26/5/18 ainsi que les autres avis positifs. Le câble secteur (Nordost) de mon préampli bridait la chaîne.
Après lectures sur les forums j'ai tenté ce câble. Le résultat est au delà de mes attentes, gain sur tous les paramétres. Son prix est justifié. Le rodage est long: 5 jours en fonctionnement.
Câble excellent
Aux premières heures j'ai été très déçu, le câble présentait beaucoup de duretés dans le haut médium et un grave écourté, comme le disent certains commentaires. Mais le rodage règle ce problème.
Je le possède à présent depuis plusieurs années et il fait partie de mes câbles préférés.
Ce FP3TS20 est à brancher sur des appareils qui consomment peu, les DACs, préamplis et amplis casque sont parfaits pour lui.
Ce FP3TS20 présente une écoute très vivante, avec des basses épaisses, bien tenues et qui descendent très bas. Le médium est sans brillance, et bénéficie d'une belle onctuosité, les notes semblent durer un peu plus longtemps, signe d'une écoute plus détaillée.
Les aigus sont très vivants. Ce n'est pas un câble euphonique type Yarbo qui gomme un peu l'extrême aigu pour calmer le jeu, on a affaire ici à des aigus de grande qualité, réalistes, détaillés et raffinés, qui donnent de l'énergie à la musique, sans excès toutefois (ce n'est pas un câble montant/brillant/clair).
L'écoute devient à la fois charnelle (par l'onctuosité du médium et l'épaisseur des bases) et très vivante: c'est excellent.
Vaut très, très largement la dépense à mon avis.
Long rodage à prévoir.
 (9)
