FURUTECH FP-S032N Power Cord Cable OFC Copper (Alpha) 3x2.5mm² Ø16mm
The FP-S032N is an ultra-high-performance 3-conductor power cable for uncompromising audio applications. Its build quality and technical features leave no doubt as to Furutech's premium positioning.
By buying this product you get 36 loyalty points
Reference : 11123
129,00 €tax incl.
107,50 € tax excl.
Shipping date: 16-06-2026.
Câble au mètre - Secteur, modulation, HP
FURUTECH FP-S032N
Each conductor consists of a central core made up of 1 x 37 strands of 0.25mm diameter OFC Alpha α copper, 2 x 37 strands of silver-plated copper, i.e. three times 2.5mm².
Each of these strands is individually insulated within a 3.4mm-diameter polyethylene sheath. The assembly is then double protected with a 12mm PVC inner sheath and a braided copper shield. This braided sheath comprises 9x24 strands of 0.12mm type Alpha α conductors.
As is standard practice for this manufacturer, all metals will have benefited from the proprietary Alpha α anti-magnetism process, itself based on 2 steps:
1 - Cryogenization of the metals by -250°C using liquid nitrogen, with the aim of consolidating their molecular structure and considerably improving their conductivity.
2 - Treatment of the same metals with a powerful magnetic field created by ring magnets, whose force of attraction is constantly monitored so as to leave no magnetic residue at the end of the treatment.
This second stage, developed in collaboration with the Japanese firm SEKIGUCHI MACHINE SALES, helps make FURUTECH cables exceptional conveyors for any electrical signal used in sound reproduction.
Specifications :
  • Very High Performance 3-Conductor power cable.
  • 3 conductors with a unit cross-section of 2.5mm², consisting of a total of 3 x 37 μ-OFC (Alpha) copper strands.
  • Polyethylene insulation, 3.4mm diameter, covered with a PTFE insulating film and color-coded (Red / Yellow / White).
  • High-flexibility black PVC inner jacket.
  • Total cable diameter: 16mm.
  • External sheathing in Dark Blue PVC for very high resistance.
  • Color code: Brown = Phase / Blue = Neutral / Green with yellow edging = Earth.
  • Cable sold by the meter
https://www.audiophonics.fr/images2/4889_FURUTECH_FP-3TS20_7.jpg
Diameter (mm)16.0
Length (m)Sold by length
Number of conductors3
Insulation materialPE
ShieldingYes
Section (mm²)2.5
ConnectorN/A
Ground / ShieldingYes
8 reviews
Un Must
Si comme moi vous écoutez des musiques modernes à bas ou à fort volume ce câble est un des meilleurs. Je l'ai comparé et associé avec du furutech fp-tcs31 ainsi que le oyaide Vondita... rien à faire, fp-s032n sur la barette et fp-s032n sur l'ampli. Neutre, précis, dynamique un grave profond et tenu. C'est bien ce que j'avais pu lire en commentaire, les 2 autres sont plutôt adaptés aux sources.
This review has been posted for FURUTECH FP-S032N Power Cord Cable OFC Copper (Alpha) 3x2.5mm² Ø16mm
cable secteur FP-S032N
cable monté avec des fiches furutech fi48 rhodium et utilisé sur un lecteur réseau melco , après quelques heures de rodage je peux donner un avis très positif ; ce cable est neutre en comparaison du tcs 31 que j'utilise( plus lourd dans les basses !) , très bonne dynamique, des aigus très fins et des médiums fluides , bonne cohérence des registres et pas d’agressivité; comparé à un gigawatt lc3 évo il se comporte très bien , il faut dire que les fiches furutech utilisées participent au résultat . ceci est un avis personnel et dépend des appareils utilisés mais je recommande ce produit .
La bonne affaire !
L'avis que je viens de donner était pour le tc 31, pour le 32, je peux assurer qu'il boost la dynamique, ce câble est fait pour les amplis, le mien semble avoir gagné des watts pour pas chère. Je recommande.
Un vrai câble premium
Câble que je trouve assez neutre au niveau des registres ce qui pour moi est une qualité, la scène sonore s'est encore agrandie, les musiciens se sont légèrement rapproché.
Le rapport qualité prix est incontestable.
Top
Je voulais écouter la différence sur mon ampli Exposure avec le tcs31 que j'ai depuis un moment, plus chaleureux. Le s032n est plus naturel tout en restant feutré, et plus ouvert.L'aigu est plus défini mais pas fatigant.Excellent câble (comme le tcs31 d'ailleurs).
 (3)
The FP-S032N is an ultra-high-performance 3-conductor power cable for uncompromising audio...
