FURUTECH FP-TCS21 OFC (Alpha) Power Cable Ø12.8mm
A very high performance 3-conductor mains cable dedicated to uncompromised audio applications, the FP-TCS21 is a high-quality, high-quality, high-end technology. This mains cable is the result of great know-how.
4.3 / 5
By buying this product you get 27 loyalty points
Reference : 10613
95,00 €tax incl.
79,17 € tax excl.
Shipping date: 24-04-2025.
Like everyonetheir products, each conductor undergoes an Alpha cryogenic treatment in order to optimize its conductivity.
1-Cryogenization of the metals by -250 ° C. using liquid nitrogen in order to consolidate their molecular structure and significantly improve their conductivity.
2- Soumission of these same metals to a strong magnetic field created by means of magnets arranged in rings and whose attraction force is constantly controlled in order to leave no residual magnetic at the end of the treatment.
Features:
  • 3-conductor High Performance
  • 3 Conductors Alpha PC-Triple C Copper OFC Single section 1.63 mm²
  • PVC insulation of 3.5mm diameter
  • PVC Black Internal High Flexibility of 9.6mm diameter
  • Shielding Braid based on 0.12mm diameter OFC copper wire
  • Dark Green PVC Envelope High Density Green
  • Total Cable Diameter: 12.8mm
Diameter (mm)12.8
Length (m)Sold by length
Number of conductors3
Insulation materialPVC
ShieldingYes
Section (mm²)1.63
Ground / ShieldingYes
4 reviews
Nice cable for amplifiers / Joli câble pour amplificateurs
I use this one for amps and the 022 is better for digital equipment.
With this cable and the corresponding plugs (rhodium for a typical high end feel or gold for more emotion) one can easily make a very good cable for very little money.
/ utilisez celui-ci pour les amplis et le 022 est meilleur pour les équipements numériques.
Avec ce câble et les fiches correspondantes (rhodium pour une sensation typiquement “ high end” ou or pour plus d'émotion) on peut facilement fabriquer un très bon câble pour très peu d'argent.
This review has been posted for FURUTECH FP-TCS21 OFC (Alpha) Power Cable Ø12.8mm
rectification de mon commentaire précédent
Et bien il ne m'aura pas fallu 1 mois pour remettre en place l'Elecaudio , avec ce Furutech assez vite apparait une fatigue auditive : trop précis trop "chirurgical" au détriment de l'émotion. Je possède aussi un FURUTECH FP-S022N qui ne pose pas ce genre de problème , beaucoup plus équilibré.
Essai validé !
Acheté pour remplacer un Elecaudio CS32 qui alimentait mon lecteur CD (MT CD One), c'est quasiment un copié-collé du commentaire précédent. Impératif : attendre au moins une cinquantaine d'heures avant de se faire une idée ++. Effectivement le maitre mot c'est précision , pleins de petits détails apparaissent , ils existaient avec l'Elecaudio mais ils étaient "noyés dans la masse" . Le Furutech donne une scène spatiale beaucoup plus précise , et beaucoup de délicatesse aux aigus. Monté avec des fiches Furutech Cu simples.
Alors si au bout d'un mois c'est encore meilleur...
Une bellle découverte !
Finesse, rapidité, clarté, neutralité, précision; sont les grande qualité de ce câble, sa section, qui n'est pas celle indiqué est environ de 2.2mm2. il remplace de façon très avantageuse le FP-3ts20 de la même marque, il mérite de très bonne prises secteur, si l'on désire en tirer la quintessence.
attention , résultat optimum après un mois de rodage.
A very high performance 3-conductor mains cable dedicated to uncompromised audio applications, the FP-TCS21 is a high-quality, high-quality,...
