FURUTECH FP-TCS31 Power cable Alpha High purity OFC Shielded 3x2.5mm² Ø16mm
By buying this product you get 51 loyalty points
Reference : 9873
175,00 €tax incl.
145,83 € tax excl.
Shipping date: 25-09-2026.
Resolutely high-end of the famous brand, this elitist sector cable represents the culmination of a great know-how.
Like all their products, each conductor undergoes an Alpha cryogenic treatment in order to optimize its conductivity:
1- Cryogenization of metals by -250 ° C using liquid nitrogen in order to consolidate their molecular structure and significantly improve their conductivity.
2- Submission of these same metals to a powerful magnetic field created by means of magnets arranged in rings and whose attraction force is constantly controlled in order to leave no residual magnetic at the end of the treatment.
This drytechnical wave, developed in collaboration with the Japanese firm SEKIGUCHI MACHINE SALES, participates in making cables FURUTECH of the conveyors of exceptions for any electric signal invested in the sound reproduction.
TypeHigh Performance Conductor.
ConductorsCopper α (Alpha) OFC High purity (99.996%).
Conductors diameter3 x 2.5mm⌀
InsulationSoft PVC insulation of 5mm diameter.
External envelopegreen PVC High resistance.
Shielding0.12mm braided OFC copper strands.
Tensile strength250 MPa.
Conductivity index101.5% IACS.
Elasticity of conductors35%.
Total cable diameter16mm
Diameter (mm)16.0
Length (m)Sold by length
Number of conductors3
Insulation materialPVC
ShieldingYes
Section (mm²)2.5
ConnectorN/A
Ground / ShieldingYes
20 reviews
TCS31 Review
I've never had a similar experience with any cable I've bought for audio. I knew from other reviews that this cable has a long break in time and that it may sound bad when it's new.
Well, it sounded so bad when new that I questioned my hearing and my system to the point that I even thought about giving up on hifi altogether and selling all my stuff. I'm not kidding, it was that bad. The sound was bright, flat and completely lifeless. It was a pure anxiety creating device.
After about 5 days of leaving my integrated amplifier (Nu Vista 600.2) on with this cable it suddenly came to life and now it's better than any power cable I've tried, even more expensive ones.
I'm giving it 5 stars because the end result is totally worth it, but be prepared for a rollercoaster ride in the first few days. After two days it sounded decent, but then it sounded bad again, only to settle after 5 days.
I can't even begin to understand how a power cable can do this.
This review has been posted for FURUTECH FP-TCS31 Power cable Alpha High purity OFC Shielded 3x2.5mm² Ø16mm
Le plus équilibré et musical de la marque !!
Après quelques autres tests Furutech, je constate que ce TCS31 est très équilibré et le plus musical des câbles secteur de la marque sur les sources. Restitution précise, détaillée mais sans coquetterie ni dureté dans les aigus, avec un grave propre et tenu. Attention cependant aux connectiques associées. Avec les ETI, c'est vraiment magnifique !! Belle découverte.
Quelle beauté dans les timbres !
Je suis ébloui par la beauté des timbres qu’offre le FP-TCS31. Je l’ai sur mon préampli et sur le transport CD. Aucune envie de changer !
Il faut toutefois bien respecter le rodage , une centaine d’heures je dirais, mais il me semble que le câble continue même de s’améliorer au-delà . Patience donc.
Une recommandation : le câble a une tendance à mettre en avant le bas-médium lui conférant une petite coloration. Pour ma part, j’ai quelque peu gommé cet excès de chaleur en associant au câble d’excellents connecteurs rhodium, à savoir le FI-50 NCF pour l’IEC et le FI-E38 R pour le Shucko. Pour moi, la combinaison est parfaite.
Un très beau câble, riche en détails offrant une vaste scène sonore et de magnifiques timbres, naturel et ne provoquant aucune fatigue à l’écoute. Un cinq étoiles !
Very good, high resolution, high end cable.
Very good! Makes a difference. Price justified. But you have to know: It brings out the highs! If your system is already a bit too bright this cable might not be for you. Tried it with my Hegel amp and my tube amp. Crisp, Clear, Good Resolution, Dynamic. With my Hegel amp the sound becomes a bit too bright but with my el-34 tube amp it makes a crisp dynamic resolving sound. Maybe the base gets a bit less with this cable but the base will be less boomy but accurate and more tight. I think this cable is mostly about resolution in all frequency ranges. Very good I think!
Équilibre et performance
Ce câble est très équilibré et ne zoom pas le haut du spectre « ouf » Aucunes fatigue!
Il à même gommé une très légère acidité sur certains aigus qui était de trop dans la musique de qualité moyenne.
La force de ce câble est le médium qui est chaleureux et bien présent sur les voix.
je ne trouve pas une grande différence sur les graves profond .
Le changement globale de sonorité entre les câble secteur et très discuté mais oui il y a une équilibre différent à l’écoute mais Il faut une électronique derrière et des enceintes qui peuvent vous donner cette chance de le percevoir, est ce n’est pas à 20% de volume qu’il y aura une différence mais plutôt dans les écoutes assez soutenue ou les défauts et qualité sont mis en évidence d’un système.
Je conseil ce câble pour écoute neutre et agréable sans faire de fausse notes.
Merci
