NEOTECH NEP-3002G Power Cable
Neotech NEP-3002G is a mains cable made up of 3 multi-stranded conductors in G-UPOCC copper, a combination of OCC copper and graphene, with a total cross-section of 4.17mm² (11AWG) and a diameter of Ø15mm. This new conductor marks a significant advance, both in terms of research and industrial applications. The addition of graphene improves the stability of electrical signal transmission at high temperatures, while preserving the exceptional conductivity of OCC copper, so that performance remains intact, even at high voltages.
Reference : 19920
159,00 €tax incl.
132,50 € tax excl.
Shipping date: 24-04-2025.
Câble vendu au mètre
Neotech NEP-3002G Power Cable Graphene Copper G-UPOCC 4.17mm² Ø15mm
Neotech NEP-3002G : Front view
Neotech NEP-3002G is a power cable made up of three multi-stranded conductors in G-UPOCC copper, a combination of OCC copper and graphene, with a total cross-section of 4.17mm² (11AWG) and a diameter of Ø15mm. This new conductor marks a significant advance, both in terms of research and industrial applications. The addition of graphene improves the stability of electrical signal transmission at high temperatures, while preserving the exceptional conductivity of OCC copper, so that performance remains intact, even at high voltages.
This top-of-the-range cable features PVC LC3 insulation, cotton fibre and a PVC outer jacket. A double shield made of Al-Mylar aluminium and tinned OFC braided copper foil also effectively protects this cable from EMI/RFI interference. This cable is ideally suited to the manufacture of mains power cables for Hi-Fi products requiring powerful, clean power.
Product typePower cable
Number of conductors3
Cross-section4.17mm² (11AWG)
Total cable diameterØ15mm
Conductive materialGraphene copper G-UPOCC
Insulation materialsPVC CL3 + Cotton fiber
ShieldingAluminium Al Mylar
Tinned OFC copper foil
Sheath materialPVC
ColorGrey
PackageSold by the meter
Diameter (mm)15.0
Insulation materialPVC
Insulation materialCotton
ShieldingYes
Section (mm²)4.17
Conductors material (Cable)Graphene
Ground / ShieldingYes
NEOTECH NEP-3002G Power Cable Graphene Copper G-UPOCC 4.17mm² Ø15mm
Neotech NEP-3002G is a mains cable made up of 3 multi-stranded conductors in G-UPOCC copper, a combination of OCC copper and graphene, with a total...
