Neotech's NEP range consists of high-end power cables using only extremely pure UP-OCC copper conductors. The NEP-3200 is therefore no exception with 16 UP-OCC copper conductors with a 9AWG (6.63mm²) total section. The 16 conductors of 17AWG (1.5mm diameter) are individually sheathed and insulated with Teflon and Al-mylar. This cable is particularly effective for high current amplifiers as well as multirpises or line conditioners.
This cable sold by the meter will therefore allow you to design very high quality power cables, also perfectly suited to conveying high currents for heavy-duty HiFi systems. In addition, the excellent quality of transmission of the electrical signal allowed by these cables makes it possible to offer a very good sound reproduction by gaining in dynamics.
Product type | Power cable |
Conductors number | 16 |
Conductor material | UP-OCC Copper |
Conductors total section | 9AWG (6.63mm²) |
Outer diameter | Ø15.6mm |
Conductor plating | Silver |
Insulation / Shielding | Teflon + Al-mylar |
External sheath | PVC |
Cable color | Black |
Package | Sold by meter |
Diameter (mm) | 15.6 |
Length (m) | Sold by length |
Number of conductors | 16 |
Insulation material | Al-Mylar |
Insulation material | PTFE |
Insulation material | PVC |
Shielding | Yes |
Section (mm²) | 6.63 |
Connector | N/A |
Conductors material (Cable) | Copper |
Conductors Plating (Cable) | None |
Ground / Shielding | Yes |
