OLFLEX 100CY Shielded Cable 3x2.5mm² Ø 11.8mm
4.6 / 5
Reference : 2059
5,60 €tax incl.
4,67 € tax excl.
Shipping date: 24-04-2025.
Cable with color-coded conductors and copper braid shielding
External Diameter: 11.8mm
Respects electromagnetic compatibility
Application domain :
Connecting cables of this type can be used in all areas where disturbing electric fields may interfere with the transmission of signals, eg in the presence of electric motors with static frequency converters. In this way, the electronics have a cable for weak or strong currents, which allows the transmission of signals by minimizing external interference. In high current applications, these screen cables will be used to prevent the propagation of disturbing effects from the cable network to the outside.
Specials:/ Span>
The shielding braid in tinned copper wires associatesfunctionality and aesthetics of the cable (transparent sheath). It is characterized by high performance and low coupling resistance (max. 250 ohms / km at 30 MHz).
Constitution:
Bare copper fine conductors, conductive insulation made of special PVC, layered connection, color-coded conductors, special PVC-based stuffing box. Tinned copper wire shielding, transparent protective sheath in special PVC-based mixture, non-flame retardant (IEC 332.1).
The special PVC P 8/1 insulating the conductors is subjected to a test voltage of 4 kV guaranteeing a high level of safety. From 1.5 mm² of cross-section, this cable is suitable for a nominal voltage of 450/750 V.
This product complies with Directive 73/23 / EEC ("Low Voltage Directive")
Technical data:
Minimum bending radius:
Fixed:
6 x Diameter
Temperature range:
Mobile: -5 ° C to + 70 ° C
Fixed: -40 ° C to + 70 ° C
Constitution of the soul:
Complies with VDE0295
Klasse 5 / IEC 228 Cl.5
Test voltage:
4000 V
Rated voltage U0 / U:
From 1.5 mm²: 450/750 V
Insulation:
Pictures version 110CY
(numbered conductors and smaller diameter)
Diameter (mm)11.8
Length (m)Sold by length
Number of conductors3
Insulation materialPVC
ShieldingYes
Section (mm²)2.5
ConnectorN/A
Ground / ShieldingYes
14 reviews
Surprenant
Peut-être le meilleur câble que j'ai essayé depuis plus de 30 ans, même comparé aux câbles coûtant plus de 400 €. (J'avais déjà Furutech, Neotech, W&M, Yarbo, Qed, Audioquest). Ce que fait ce câble en présentant l'image sonore est phénoménal et dans tous les paramètres, nous avons un son plus cristallin, des basses rapides et en même temps très naturel et plein d'énergie. Les médiums et les aigus avec une excellente beauté et transparence du timbre. De construction simple mais exemplaire, la magie de la performance sonore est aussi capable de grâce à la qualité du cuivre là où il n'y en a pas. doit être étranger à la fabrication européenne.
This review has been posted for OLFLEX 100CY Shielded Cable 3x2.5mm² Ø 11.8mm
Correct pour le prix
Quelques précisions : les câbles internes sont aux couleurs standard : marron , bleu et jaune-vert , pas de drain il faut le fabriquer a partir de la tresse , aucun marquage sur la gaine indiquant un sens de branchement , la structure des câbles multibrins semble identique à ceux que l'on trouve en magasin de bricolage . Donc si vous avez besoin d'un câble standard avec un blindage , c'est parfait !
olflex cable secteur 2.5
cable rigide haute qualité pour cordon secteur platine CD le grave sonne beaucoup mieux c est un cordon équilibré a chaque étage
Qualité-prix excellent
J'enrage, j'ai acheté du câble d'alimentation plaqué argent (qui n'est pas vendu ici) 5 fois plus cher, il n'y a rien qui va. Par dépit j'ai essayé d'autres câbles que j'avais en stock, pareil, et j'avais un bout de ce câble, je l'ai monté entre mon ampli Yamaha A-S2100 et la platine CD-S1000 et miracle, tout est meilleur, le placement des instruments, les graves propres et bien présents, les voix, tout est mieux pour un prix presque dérisoire, du coup je vais le monter sur tous mes lecteurs et l'essayer sur les deux amplis, hifi et HC.
Excellent !!!
Difficile de trouvez mieux pour ce prix
Même au dessus de certaine marque 10 fois plus chère
Vos amplificateur vont enfin s’exprimer sans retenue
