SOMMERCABLE NYM-ST-J OFC Copper Power Cable 3x2.5mm² Ø10.9mm Gray
This NYM-ST-J power cable from Sommercable includes three OFC copper conductors with a cross-section of 2.5mm². The cable has the particularity of benefiting from a very effective EMC shielding that considerably reduces electromagnetic interference.
4.7 / 5
Reference : 9867
4,90 €tax incl.
4,08 € tax excl.
Shipping date: 23-04-2025.
Sommercable NYM-ST-J Câble Secteur Cuivre OFC 3x2.5mm² Ø10.9mm Gris
This cable is manufactured by General Cavi and distributed by Sommercable.
This NYM-ST-J power cable from Sommercable includes three OFC copper conductors with a cross-section of 2.5mm². The cable has the particularity of benefiting from a very effective EMC shielding that considerably reduces electromagnetic interference, which could alter the quality of the signal passing through and generate noise. This shielding makes this cable an ideal ally for cabling, whether indoor or outdoor, as long as it is not directly exposed to the sun's rays. The cable complies with VDE 0250, VDZ 0482-332-1-2 and IEC C60332-1 standards, as well as EWG93/68 and EWG73/23. It is ideal for fixed installations, especially in sensitive areas.
Product typePower cable
Conductors materialOFC Copper
Number of conductors3
Conductors section2.5mm² (13AWG)
Conductors diameterØ1.78mm
External cable diameterØ10.9mm
ShieldingAluminum/Platinum foil + Tinned drain wire
Sheath materialPVC, retardateur de flamme
Nominal voltage500V
Weight / meter208g
Min / Max temperature-40°C / +70°C
Insulation / km resistance0.020GΩ
Cable colorGray
QuantitySold per meter
Diameter (mm)10.9
Length (m)Sold by length
Insulation materialPVC
ShieldingYes
Section (mm²)2.5
ConnectorN/A
Ground / ShieldingYes
15 reviews
Superb quality
This thing is the real deal. I made a power strip with it to have my dedicated power line from the wall. I used a Panasonic no-cable power strip and a Legrand plug. I was using a Bachmann power strip before. Improvements across the board, but especially the bass is phenomenal. Even if it's a bit stiff, copper is not a hard metal and you can easily shape the cable and it will stay in place without issues. Highly recommended!
This review has been posted for SOMMERCABLE NYM-ST-J OFC Copper Power Cable 3x2.5mm² Ø10.9mm Gray
Amazing sound, in-wall cable
I was expecting a less rigid cable, this is definitely not the best choice for your standard IEC cables. The copper is a SOLID CORE inside, which makes this cable extremely rigid. You bend it and it stays like that. I would definitely use this as an in-wall cable as it has the certifications you need and would do the job (if you don't bend it too much). Out of necessity however, I have built a component Schuko-IEC cable with it and it sounds mind-blowingly good! If I had to run a new power line to my Hi-Fi rig, I would probably use these now.
Vraiment rigide !!
J'avais lu que ce câble (marqué Général Cavi) est rigide.
Ayant coupé une longueur de 0,80 mètre puis placé une prise Schuko femelle Schurter et à l'autre extrémité une prise mâle Sommercable, le câble tient droit devant moi comme un bâton.
Vraiment rigide mais je peux quand même l'utiliser pour brancher mon ampli à lampes.
Constitué de 3 fils rigides monobrins de 2.5mm2 + un fil métallique supplémentaire plus fin et monobrin aussi (que j'ai branché avec le fil de terre) parcourent ce câble, il est effectivement blindé.
Le son est clair, plus transparent qu'avec un câble secteur ordinaire.
Bon achat, je suis toujours ravi de la qualité de l'emballage et de la rapidité de livraison par Audiophonics.
superbe cable
Excellent câble hautement blindé, d'autre part sa structure mono brin permet de s'affranchir des problèmes récurant en audio (sans être un spécialiste) : stabilité et intégrité globale de la transmission du courant. Toutefois très rigide difficilement pliable, utilisé pour réaliser une multiprise 8 ports, à nécessité une hauteur interne de celle-ci de 10 cm, pour s'affranchir de la courbure maximale possible.
Équilibré
Pour un système secondaire c’était l’occasion d’essayer. Pas cher mais efficace. Connecté à une audiophonic PS24RA et à une Iec tout cuivre … Relié à un distributeur 4 prises audiophonic. Le son du système est plus équilibré, posé, plus dynamique, le côté un peu brouillon de l’ancienne belkin sur les masses orchestrale à disparu.
Sur du Pink Floyd la spacialisation a fait un bon. Le grave mieux tenu. RQP imbatable et ça marche. Surtout que le CD Teac et l’ampli teac (datant des années 1980) ont des câbles prisonniers. Je vais câbler un home studio avec. Pour moi le Résultat est probant. Neutre équilibré, Silence…pour un petit prix.
This NYM-ST-J power cable from Sommercable includes three OFC copper conductors with a cross-section of 2.5mm². The cable has the...
