SOMMERCABLE TITANEX HAR 3G2.5 Power cable 3x2.5mm² Ø 10.5mm
4.6 / 5
Reference : 9860
4,70 €tax incl.
3,92 € tax excl.
Shipping date: 24-04-2025.
(HAR) FOR HIGH INTENSITY CURRENT
SOMMER CABLE - SC-RUBBERFLEX
You do not commit any fault ...
if you follow the current, because cables of type H07RN-F, with rubber envelope, are among the most sold on the international market. They are used as high-voltage cable for audio systems, projectors, heavy equipment (machines) and can also be used outdoors.
Thesecables are very robust. Their neoprene sheath has a long life, is very flexible and extremely resistant to abrasion.
Conforme to VDE 0282 part 4 / HD 22.453, 73 / 23EWG, EC low voltage directive.
ADVANTAGES:
  • Very reliable. Non-flammable neoprene sheath (polychloroprene rubber)
  • Very flexible (multiple strands with fine strands according to VDE 0293)
  • Suitable for outdoor use
USE:
  • Power cable for various electrical appliances
  • Audio technique (lighting rheostats, projectors, amplifiers, racks ...)
  • Mechanical engineering, agricultural machinery
Specifications:
ConstitutionH07RN-F 3x2.5mm2
Envelope, diameter10.5 mm
Copper strands per coreaccording to DIN 0293 mm
Insulation of the conductorrubber
Operating temperaturemin. -30 ° C
Operating temperaturemax. 60 ° C
Weight per m235 g
Color of envelopeblack
Packaging unit, packing unitper meter
Electrical Specifications:
Resistance, insulation1 MOhm
Test voltage2 kV
Diameter (mm)10.5
Length (m)Sold by length
Number of conductors3
Insulation materialRubber
ShieldingNo
Section (mm²)2.5
ConnectorN/A
Ground / ShieldingNo
5 reviews
excellent pour le prix
Câble Nexans titanex utilisé pour alimenter et recabler une multiprise diy . Grave et spatialisation bien meilleur que le câblage d'origine. Monté avec schuko Bals et gaine elecaudio vipera. Excellent rapport qualité prix
This review has been posted for SOMMERCABLE TITANEX HAR 3G2.5 Power cable 3x2.5mm² Ø 10.5mm
Une valeur sûre pour mélomanes, sans se ruiner
Utilisateur de Titanex 3G2.5 (sur recommandation de FIRODIL) de longue date, celui-ci propose des résultats assez chaleureux et articulés pour un prix dérisoire.
S'il n'est pas du genre à donner envie de couper les décibels en 4 ni à se pâmer "audiophilement" devant son grave, son medium ou son aigue, la cohérence mélomane qu'il procure est tout bonnement exemplaire à ce prix.
On pourra toujours pinailler ici sur plus d'aération ou là sur moins de coquetterie dans la charnière haut medium/aigüe, mais je le suspecte d'être sacrément plus homogène, plein et naturel que nombre de câbles dédiés à l'audio qui fleurissent ça et là y compris à des tarifs sensiblement supérieurs.
Et compte-tenu du sérieux d'Audiophonics, s'ils le propose, c'est qu'il y bel et bien une raison...
Bref, troquer les câbles basiques d'origine par ce Titanex 2G2.5 ne se discute pas...
 (3)
Nice presentation
I have bought for my old turntable and amplifier. For turntable I have notice that lower range is much more clear the mid and treble I didn't notice high difference, also need more time for burn out. For amplifier power cord notice difference was much higher. Immediately on lower volume output stage was much more clear, punchy and midrange was so tight that I was surprised for price to get it. Sound is more warmer but definitely for the price meets the requirements. Definitely recommend for decent power upgrade.
Très bien
Confirme pas ecrit sommercable sur le cable mais du nexans, sinon ras
satisfait
J' ai reçu ma commande rapidement comme a chaque fois, et suis globalement satisfait du service sur ce site.Mais j'ai reçu du titanex nexans au lieu du sommercable (problème de stock).Il est vrai que c'est plus ou moins la même chose mais le nexans est moins discret.Toujours est-il que j'ai équipé ma multiprise en étoile avec ce câble qui a un rendu beaucoup plus naturel que le cuivre OCC qui a tendance a être un peu terne avec des aigus ecourtés (même constat avec les modulations et les câbles hp). Pour le prix je suis satisfait.Le câble n'est pas forcemment le plus esthetique mais il fait le boulot, équipé d'une fiche et et d'embases furutech plaquées or.
