YARBO SP-9000PW Power Cable OFC Copper Double Shielded 2x6.6mm² Ø18mm
This Yarbo SP-9000PW high-end power cable only integrates high-end components. The conductors are made of high-purity OFC Copper. Each conductor is composed of 3 rectangular strands of high cross-section as well as many other copper strands of lower cross-section.
Reference : 14045
59,90 €tax incl.
49,92 € tax excl.
Shipping date: 23-04-2025.
Câble au mètre
Yarbo SP-9000PW
Power Cable OFC Copper Shielded 2x6,6mm² Ø18mm
Yarbo SP-9000PW Câble Secteur Cuivre OFC Blindé Ø18mm
This Yarbo SP-9000PW high-end power cable only integrates high-end components. The conductors are made of high-purity OFC Copper. Each conductor is composed of 3 rectangular strands of high cross-section as well as many other copper strands of lower cross-section. They are then covered with a PE sheath. The filling / insulation of the cable is made of 6 strands of FEP. The assembly is then insulated by a double shielding with a copper foil and then a copper braid. A PVC sheath and a blue and black Nylon sheath finish this cable. The Yarbo SP-9000PW also incorporates a ground wire with a diameter of Ø3mm made of OFC Copper.
Product typePower cable
Conductors materialOFC Copper
Number of conductors2 + 1 Ground wire (6,6mm² + 6,6mm² + 2,34mm²)
Filling / insulation materialFEP
ShieldingCopper foil + Copper braid
External sheathPVC
Covering sheathNylon
Total cable diameterØ18mm
Ground wire diameterØ3mm
ColorBlack and Blue
QuantityCable sold per meter
Diameter (mm)18.0
Length (m)Sold by length
Number of conductors3
Insulation materialFEP
ShieldingYes
Section (mm²)6.63
ConnectorN/A
Ground / ShieldingYes
This Yarbo SP-9000PW high-end power cable only integrates high-end components. The conductors are made of high-purity OFC Copper. Each conductor is...
