NEOTECH LECT-22 wiring cable UP-OCC PTFE 0.32mm² 22AWG
Reference : 12094
6,80 €tax incl.
5,67 € tax excl.
Shipping date: 22-04-2025.
Neotech's leading high-tech hi-fi cable continues its investigation in the field of sound reproduction and today produces the ultimate in cable modulation, digital SPDIF, AES EBU, speaker and high- End.
The Solid Rectangular Core Silver Wire cable series enables the highest quality OCC UP cables to be manufactured with high-grade PTFE dielectric insulation.
You can now design OCC pure copper cables and access the High-End references of the audiophile cable market. The method of Professor Ohno of the Chiba Institute of Technology of Japan makes it possible to raise the purity of the 99.99998% pure copper and silver strands above the level of the standard annealed OFC cables.
The oxygen particles inside the copper strands are thus reduced to an insignificant level ensuring a high level of stability over time preventing oxidation over the long term.
The series of cables to be welded Neotech LECT UP OCC exists in differents diameters matching all expectations for the informed amateur building his own Hifi cables.
This cable is particularly recommended for the assembly of high-end modulation cable.
neotech LECT 22
https://www.audiophonics.fr/img/cms/products/8941/UPOCC-1.png
Features:
    • Insulation: PTFE.
    • Conductor: UP-OCC Rectangularsolid core (Pure copper to 99.99998%)
    • Internal Width: 1.21 mm
    • Internal Thickness: 0.27 mm
    • External Width: 1.56mm
    • External Thickness: 0.64mm
    • AWG: 22
    • 7 ampere
    • Red color
    • Sold by the meter
https://www.audiophonics.fr/img/p/7/4/4/0/7440.jpg
Diameter (mm)N/A
Length (m)Sold by length
Number of conductors1
Insulation materialPTFE
ShieldingNo
Section (mm²)0.32
Ground / ShieldingNo
4 reviews
Roudoudou
Rendu sonore doux et rond.
Mais bonne dynamique et intégrité du signal. Recommandé.
This review has been posted for NEOTECH LECT-22 wiring cable UP-OCC PTFE 0.32mm² 22AWG
superbe câble en modulation ou en câblage interne d’ampli.
En gauge 20 sur la masse et en gauge 22 sur le point chaud, ce cable est une révolution. aucune tonique, une articulation redoutable et des timbres fantastiques. Le cuivre OCC mais surtout la géométrie du câble plat en fond un must.
réalisation de câble de démodulation
Le résultat du montage (prises RCA de qualité + blindage) est très bon. Je suis très satisfait du résultat dont les qualités sonores sont au moins aussi bonnes que celles obtenues avec des câbles montés bien plus onéreux ...
Superbe en câble de modulation
J’ai réalisé 2 câbles de modulation de 60cm sans blindage, simplement en torsadant légèrement les 2 conducteurs. Le résultat dépasse largement tous mes précédents essais ( et ils se comptent en centaines…) Grande articulation, excellente dynamique , belle profondeur et plus aucune crispation. Un grand sens du naturel. Je suis persuadé que la forme rectangulaire des conducteurs procure un net avantage dans la transmission des signaux en évitant de concentrer les toniques aux mêmes fréquences comme avec les conducteurs ronds
