LAPP KABEL Olflex HEAT Double flexible conductor 1mm² Red
Reference : 13050
1,80 €tax incl.
1,50 € tax excl.
Shipping date: 25-04-2025.
Cables LAPP KABEL Ölflex are recognized for their excellent heat resistance. This model can indeed withstand temperatures of -50 ° C to + 180 ° C.
Its silicone insulation keeps it much more flexible than traditional PVC cables for easy installation problems and establishment in environments where space is limited
This cable contains no halogens.
Characteristics
TypeWire ÖLFLEX HEAT 180
Number of cores2
Nominal voltage300/500 V
InsulatingSilicone
Conductor Area CSA1 mm²
Temp max150°C
Temp min-50°C
Tension test2000 V
Outside diameter6.6 mm
Weight / meter66 g
Diameter (mm)6.6
Number of conductors2
Insulation materialSilicon
ShieldingNo
Section (mm²)1.00
Conductors material (Cable)N/A
Ground / ShieldingNo
