FURUTECH CRADLE FLAT additionnal base for NCF Booster
Optionnal base to increase capacity of your Furutech NCF Booster
By buying this product you get 30 loyalty points
Reference : 13679
159,00 €tax incl.
132,50 € tax excl.
Shipping date: 16-04-2025.
Additionnal base for FURUTECH NCF SIGNAL BOOSTER
NCF Booster extension
This additional platform allows you to add more cables to a single carrier NCF SIGNAL BOOSTER.
It installs easily on Furutech extensions bars and thus saves a lot of space while enjoying optimized wiring.
A lateral clamping system makes it easy to adjust the vertical position of the platform according to the available height.
The additional platform has exactly the same specifications as the model provided initially with the NCF BOOSTER.
It is possible to mount flat base and curved base on the same stand.
TypeOptionnal piece for cable carrier
Dimensions46 x 106 x 22.5mm
Weight77.0g
MaterialsABS resin
NCF Nylon Resin
Length (m)N/A
ShieldingNC
Section (mm²)N/A
ConnectorN/A
Conductors material (Cable)N/A
