By buying this product you get 54 loyalty points
Dampening Support for Power Connectors 2 Sockets
The NCF Booster-Brace from Furutech adapts to power distributors and wall outlets to increase stability. Designed to accompany massive cables with large conductors, this accessory is for users who will stop at nothing to optimize the power supply of an audio installation.
The Booster-Brace is constructed from a hybrid NCF structure. This specially developed material incorporates a crystalline material chosen for its ability to passively eliminate static charges and efficiently dissipate thermal energy. This remarkable material is coupled with ceramic and carbon nanoparticles to provide additional piezoelectric damping and resonance absorption. The Nano Crystal² Formula is therefore an unparalleled solution for mechanical and electrical damping.
Surface channels help eliminate surface vibrations. The entire body houses a sealed cavity to provide a pressure differential and increase the isolation capabilities of the media.
The whole set is carefully protected in an anodized aluminum case that will easily fit into the aesthetics of a listening room hosting a very advanced audio installation.
Please note that the form-factor of the holder meets the specifications of the Furutech IEC / mains connectors. Be sure to check the dimensions of your cords/connectors carefully if you do not follow this recommendation.
Product type | Dampening Support for Power Connectors 2 Sockets |
Materials | NCF Anodized aluminum housing |
Dimensions | 106 x 54 x 35mm |
Internal diameter | 40mm |
Length (m) |
Shielding |
Section (mm²) |
Connector |
Conductors material (Cable) |
Conductors Plating (Cable) |
