FURUTECH NCF BOOSTER Cables and Power Connectors Holder
The Furutech NCF Booster is a support for cables and connectors with the particularity of also improving the audio performances thanks to excellent mechanical and electrical damping.
By buying this product you get 90 loyalty points
Reference : 12486
459,00 €tax incl.
382,50 € tax excl.
Shipping date: 30-04-2025.
NCF Booster
Cables & Connectors Holder
NCF Booster Support pour câbles et connecteurs
A new essential HiFi accessory
The Furutech NCF Booster is a cable and connector support that has the particularity of the performances of these. Having first been a real success in Japan, the NCF Booster now arrives on the international market!
What is the NCF Booster ?
It is a cable support and multi-material connectors improving the performance of these. Thus, the NCF Booster does not just elevate your cables from the ground to limit the contact points thus reducing electromagnetic interference. It also ensures real damping of cables and connectors, allowing optimal alignment to reduce static loads. By its action, the NCF Booster allows to obtain a signal more pure and clear.
NCF : Nano Crystal² Formula
Developed especially by Furutech, the NCF incorporates a special crystalline material with two active properties. First, it generates negative ions to eliminate static charges. Secondly, it converts thermal energy into infrared. Furutech therefore combines this material with remarkable properties with ceramic nanoparticles as well as carbon powder to ensure piezoelectric damping. The result of using the Nano Crystal² Formula is obtaining the ultimate mechanical and electrical absorber.
The NCF Booster can be combined with the Extension Shaft Bar from Furutech, to obtain an extension of the rods and therefore a higher height of elevation for your cables and connectors.
MaterialNCF
ColorBlack and Silver
Length (m)N/A
ShieldingNC
Section (mm²)N/A
ConnectorN/A
Conductors material (Cable)N/A
Conductors Plating (Cable)NC
2 reviews
Très efficace
Je l'ai positionné sous la prise secteur qui alimente la barrette de mes appareils. La scène sonore est mieux perçue, surtout au fond. Une réelle clarté s'entend précisément sans effort. Les instruments deviennent plus réaliste, surtout sur les cuivres, cymbales et autres percussions.
Cet article est réellement un plus pour un système déjà bien abouti.
Je suis très content de cet achat.
 (3)
This review has been posted for FURUTECH NCF BOOSTER Cables and Power Connectors Holder
soigner l'alimentation electrique
Excellent et efficace support pour cable secteur . Fabrication très soignée .
Personnellement il fait merveille sur la prise IEC d'alimentation de mon conditionneur Gigawatt PC3 evo. Son apport sur la "propreté" du son est réel meme si l'on ne doit pas s'attendre à une revolution ! Malgré tout sur un système abouti , il apporte incontestablement un plus ! Dommage qu'il soit si onéreux ! J'ai commandé le booster signal pour effectuer un essai avec les cables interconnexion ! à suivre !!!
The Furutech NCF Booster is a support for cables and connectors with the particularity of also improving the audio performances thanks to excellent...
