FURUTECH NCF BOOSTER-SIGNAL-L Flat Support for Cables and Connectors
Furutech's NCF Booster Signal L, a version of NCF Booster Signal, is a cable and connector holder designed to improve cable and connector performance. Having been a real success in Japan, it then entered the international market. In this "L" version, the cable is always placed on the upper flat part of the support, but the foot is much flatter, allowing you to position your cables at much lower heights.
3.5 / 5
By buying this product you get 40 loyalty points
Reference : 14024
209,00 €tax incl.
174,17 € tax excl.
Furutech NCF Booster-Signal-L
Furutech NCF Booster Signal L Support Plat pour Câbles et Connecteurs
An essential HiFi accessory
Furutech's NCF Booster Signal L, a version of NCF Booster Signal, is a cable and connector holder designed to improve cable and connector performance. Having been a real success in Japan, it then entered the international market. In this "L" version, the cable is always placed on the upper flat part of the support, but the foot is much flatter, allowing you to position your cables at much lower heights. It can therefore be particularly useful for supporting cables at the output of devices with low connectors.
What is the NCF Booster?
It is therefore a multi-material cable and connector holder, improving their performance. Thus, NCF Booster Signal L not only raises your cables from the ground to limit contact points to reduce electromagnetic interference, it also provides real damping of cables and connectors, allowing optimal alignment to reduce static charges. By its action, the NCF Booster Signal L allows to obtain a purer and clearer signal.
Examples of use of the NCF Booster Signal L
NCF : Nano Crystal Formula²
Specially developed by Furutech, NCF incorporates a special crystalline material with two active properties. First, it generates negative ions to remove static charges. Second, it converts thermal energy into infrared. Furutech therefore combines this material with remarkable properties with ceramic nano-particles and carbon powder. This ensures piezoelectric damping. The result of using the Nano Crystal Formula² is the ultimate mechanical and electrical damping.
Design of the NCF Booster Signal L
1Multi-material NCF support. ABS and Nylon resin.
2Plateau amortissant
3Vibrations transmission axis
4Vibrations suppresion plate (damping). Structure to avoid resonance.
5Semi-sealed inner chamber. The internal air pressure is resistant to vibration.
The NCF Booster Signal L can be combined with Furutech extension bars for a higher elevation of your cables and connectors (sold separately, see accessories).
Product typeCable and connectors support
MaterialMulti-material:
NCF
High quality ABS
Nickel-plated brass
Nylon resin
Support typeFlat
Min / Max height23.8mm / 81.4mm
Base dimensions89.8 x 66mm
Overall dimensions46 x 106mm
ColorsBlack and Silver
Length (m)N/A
ShieldingNC
Section (mm²)N/A
ConnectorN/A
Conductors material (Cable)N/A
2 reviews
2eme avis ( y a du mieux)
suite à mon précédent avis mitigé j'ai testé cet article sur ma chaine secondaire moins optimisée . Situé sous la fiche iec du cable d'alimentation de l'ampli le son se révèle plus net mais sans aseptisation comme constaté sur mon système principal . 4 étoiles dû au prix pas en adéquation avec le résultat .
This review has been posted for FURUTECH NCF BOOSTER-SIGNAL-L Flat Support for Cables and Connectors
Le son se modifie mais est il meilleur ? rqp élevé
Ma chaine dispose de plusieurs câbles secteur stealth audio . Essayé sous le câble de l'ampli puis sous la prise du câble d'alimentation général . Je constate un son lissé et plus propre mais moins impliquant qu'avec les supports que j' ai fabriqué avec des supports de manche à balai muraux surmontés d'absorbants acheté sur ce même site . Cependant le son reste bon avec ce booster signal mais il s'agit sur mon système d'un autre type d'écoute plus rectiligne et avec moins de relief . Mon avis n'engage que moi mais ne justifie pas ce prix qui me semble élevé pour le résultat . A voir selon les systèmes .
Furutech's NCF Booster Signal L, a version of NCF Booster Signal, is a cable and connector holder designed to improve cable and connector...
