Viablue Rocket Black
This Viablue Rocket cable holder set protects your cables from vibration and resonance. They also prevent the formation of capacitance between the ground and the cable. They're ideal if you need to decouple the cable from the ground.
By buying this product you get 31 loyalty points
Reference : 18521
319,00 €tax incl.
265,83 € tax excl.
VIABLUE ROCKET Cable Holder Black (set x4)
View of the VIABLUE ROCKET cable holder
KEY FEATURES:
  • Solid aluminum body
  • Scratch-resistant surface finish
  • Optimum stability thanks to high weight
  • Innovative, non-slip VIABLUE™ soft bearings
  • Soft VIABLUE™ rings for flexible, vibration-reducing cable attachment
Viablue Rocket cable supports: easy installation
Viablue Rocket cable supports feature 2 levels and flexible rings to securely fasten cables.
Installation of Viablue Rocket cable holders
Exemple d'utilisation des supports de câble Viablue Rocket Viablue Rocket cable holder dimensions
Technical charateristics
Product typeCable holder
Body materialSolid aluminum
Max. cable diameter2x Ø20mm
Cable heightMin. 53mm
Max. 79mm
Total dimensions94 x 58mm
Weight233g/Cable holder
PackageSet x4
Length (m)N/A
ShieldingNC
Section (mm²)N/A
ConnectorN/A
Conductors material (Cable)N/A
Conductors Plating (Cable)NC
VIABLUE ROCKET Cable Holder Black (Set x4)
This Viablue Rocket cable holder set protects your cables from vibration and resonance. They also prevent the formation of capacitance between the...
