Viablue Rocket XL Black (Set x8)
This Viablue Rocket XL cable holder set protects your cables from vibration and resonance. They also prevent the formation of capacitance between the ground and the cable. They're ideal if you need to decouple the cable from the ground.
By buying this product you get 89 loyalty points
Reference : 18556
899,00 €tax incl.
749,17 € tax excl.
VIABLUE ROCKET XL Cable Holder Black (Pair)
View of the VIABLUE ROCKET XL cable holder
This Viablue Rocket XL cable holder set protects your cables from vibration and resonance. These Viablue holders also prevent the formation of capacitance between the ground and the cable. They're ideal if you need to decouple the cable from the ground.
KEY FEATURES:
  • Solid aluminum body
  • Scratch-resistant surface finish
  • Optimum stability thanks to high weight
  • Innovative, non-slip VIABLUE™ soft bearings
  • Soft VIABLUE™ rings for flexible, vibration-reducing cable attachment
Viablue Rocket XL cable supports: easy installation
Viablue Rocket XL cable supports feature 2 levels and flexible rings to securely fasten cables.
Installation of Viablue Rocket XL cable holders
Exemple d'utilisation des supports de câble Viablue Rocket XL Viablue Rocket XL cable holder dimensions
Technical charateristics
Product typeCable holder
Matériau du corps Solid aluminum
Max. cable diameter2x Ø30mm
Cable heightMin. 75mm
Max. 107mm
Total dimensions128 x 78mm
Weight462g/Cable holder
Packagex8 cable holders
Length (m)N/A
ShieldingNC
Section (mm²)N/A
ConnectorN/A
Conductors material (Cable)N/A
Conductors Plating (Cable)NC
VIABLUE ROCKET XL Cable Holder Black (Set x8)
This Viablue Rocket XL cable holder set protects your cables from vibration and resonance. They also prevent the formation of capacitance between...
