Viablue Rocket XL Silver
This Viablue Rocket XL cable holder set protects your cables from vibration and resonance. They also prevent the formation of capacitance between the ground and the cable. They're ideal if you need to decouple the cable from the ground.
Reference : 18524
249,00 €tax incl.
207,50 € tax excl.
Shipping date: 16-04-2025.
VIABLUE ROCKET XL Cable Holder Silver (Pair)
View of the VIABLUE ROCKET XL cable holder
This Viablue Rocket XL cable holder set protects your cables from vibration and resonance. These Viablue lifters also prevent the formation of capacitance between the ground and the cable. They're ideal if you need to decouple the cable from the ground.
KEY FEATURES:
  • Solid aluminum body
  • Scratch-resistant surface finish
  • Optimum stability thanks to high weight
  • Innovative, non-slip VIABLUE™ soft bearings
  • Soft VIABLUE™ rings for flexible, vibration-reducing cable attachment
Viablue Rocket XL cable supports: easy installation
Viablue Rocket XL cable supports feature 2 levels and flexible rings to securely fasten cables.
Installation of Viablue Rocket XL cable holders
Exemple d'utilisation des supports de câble Viablue Rocket XL Viablue Rocket XL cable holder dimensions
Technical charateristics
Product typeCable holder
Matériau du corps Solid aluminum
Max. cable diameter2x Ø30mm
Cable heightMin. 75mm
Max. 107mm
Total dimensions128 x 78mm
ColorSilver
Weight462g/Cable holder
PackageSold by pair
Length (m)N/A
ShieldingNC
Section (mm²)N/A
ConnectorN/A
Conductors material (Cable)N/A
Conductors Plating (Cable)NC
This Viablue Rocket XL cable holder set protects your cables from vibration and resonance. They also prevent the formation of capacitance between...
