By buying this product you get 89 loyalty points
This Viablue Rocket XL cable holder set protects your cables from vibration and resonance. These Viablue lifters also prevent the formation of capacitance between the ground and the cable. They're ideal if you need to decouple the cable from the ground.
KEY FEATURES:
Viablue Rocket XL cable supports feature 2 levels and flexible rings to securely fasten cables.
Technical charateristics
Product type | Cable holder |
Matériau du corps | Solid aluminum |
Max. cable diameter | 2x Ø30mm |
Cable height | Min. 75mm Max. 107mm |
Total dimensions | 128 x 78mm |
Color | Silver |
Weight | 462g/Cable holder |
Package | Sold by 8 |
Length (m) | N/A |
Shielding | NC |
Section (mm²) | N/A |
Connector | N/A |
Conductors material (Cable) | N/A |
Conductors Plating (Cable) | NC |
