VIABLUE UFO DOME Silver
This Viablue UFO DOME cable holder set protects your cables from vibration and resonance. They also prevent the formation of capacitance between the ground and the cable. They're ideal if you need to decouple the cable from the ground.
By buying this product you get 28 loyalty points
Reference : 18526
289,00 €tax incl.
240,83 € tax excl.
Shipping date: 16-04-2025.
VIABLUE UFO DOME Cable holder Silver (Set x4)
Photo of VIABLUE UFO DOME cable support
KEY FEATURES:
  • Solid aluminum body
  • Scratch-resistant surface finish
  • Optimum stability thanks to high weight
  • Innovative, non-slip VIABLUE™ soft bearings
Viablue UFO Dome cable supports: easy installation
Viablue UFO cable supports are placed directly under the cables.
Installation of Viablue UFO Dome cable supports
Example of use of Viablue UFO Dome cable supportsDimensions of Viablue UFO Dome cable supports
Technical charateristics
Product typeCable holder
Body materialSolid aluminum
Max. cable diameter1x Ø30mm
Cable height41mm
Total dimensions51 x 65mm
ColorSilver
Weight315g/Cable holder
PackageSet x4
Length (m)N/A
ShieldingNC
Section (mm²)N/A
ConnectorN/A
Conductors material (Cable)N/A
Conductors Plating (Cable)NC
This Viablue UFO DOME cable holder set protects your cables from vibration and resonance. They also...
