MOGAMI 3162 AES / EBU Digital Cable 110 Ohm
Mogami offers us here a flexible multi-conductor digital audio cable with a compact design. This 110 Ω AES/EBU cable is easy to wire, install and handle. Thanks to its CPP (cellular polypropylene) insulation, the size of the conductors used can be increased furthermore while maintaining a compact overall diameter, resulting in lower attenuation.
Reference : 19119
16,90 €tax incl.
14,08 € tax excl.
Shipping date: 22-04-2025.
Câble vendu au mètre
MOGAMI 3162 AES / EBU Digital cable 110 Ohm 7x0.22mm² Ø13.8mm
MOGAMI 3162 AES / EBU Digital cable 110 Ohm 7x0.22mm² Ø13.8mm : Front view
Mogami offers us here a flexible multi-conductor digital audio cable with a compact design. This 110Ω AES/EBU cable is easy to wire, install and handle. Thanks to its CPP (cellular polypropylene) insulation, the size of the conductors used can be increased furthermore while maintaining a compact overall diameter, resulting in lower attenuation.
MOGAMI 3162 AES / EBU Digital cable 110 Ohm 7x0.22mm² Ø13.8mm : Internal diagram
Product typeDigital cable AES/EBU 110 Ohm
ConductorsCopper
Section7 x 0.22mm²
InsulationCellular polypropylene
Dual shieldingSpiral copper surrounding
External diameterØ13.8
Outer sleevePVC
PackageSold by the metre
Diameter (mm)13.8
Number of conductors8
Insulation materialPolypropylene (PP)
ShieldingYes
Section (mm²)0.22
Ground / ShieldingYes
MOGAMI 3162 AES / EBU Digital Cable 110 Ohm 7x0.22mm² Ø13.8mm
Mogami offers us here a flexible multi-conductor digital audio cable with a compact design. This 110 Ω AES/EBU cable is easy to wire,...
