Here is a MOGAMI modulation cable made by us in our workshops. Indeed, this cable is "special" with the combination of the 2 connectors: 3.5mm jack and 5 pin DIN.
The Jack connector used is a 3.5mm Jack ELECAUDIO JK3-103, with a Nickel plated brass body, and a gold plating for the upper part. The 5-pin DIN connector on the other side is specially designed for Bang & Olufsen products.
The W2549 cable uses the Neglex OFC copper from the famous Japanese brand MOGAMI to achieve an unmatched level of performance in sound reproduction.
Its 2 conductors of 0.339mm² unit section demonstrates an exceptionally low level of capacitance. The integral shielding of the conductors, as well as their twisted structure, ensure the W2549 a total immunity against electromagnetic and radio interference.
This auxiliary cable is perfectly suitable if you want to connect a bluetooth receiver, or even your phone to your Bang & Olufsen HiFi system .
Characteristics:
