By buying this product you get 22 loyalty points
Stereo XLR Interconnect Cables OCC Copper PTFE 1.5m (Pair)
The NEMOI series from Neotech is the result of extensive research in the field of audio cables. The Neotech NEMOI-3220 modulation cables combine PTFE insulation and pure OCC copper conductors with a rectangular cross-section, and are equipped with a particular architecture, allowing a strong reduction of the effect of inductance and capacitance. The result is surprising, revealing qualities often considered contradictory such as a good bass, a legible sound stage, a high definition in the midrange and a natural overall reproduction. In addition, NEMOI cables use DGA-201 locking RCA connectors with OFC copper contacts and PTFE insulation for excellent conductivity. In addition, the NEMOI cables use NC-06612 XLR connectors with gold-plated contacts and PE insulation for excellent conductivity.
Product type | XLR cables |
Length | 1.5m |
Connectors | 2* male XLR 2* female XLR |
Cable conductors material | OCC Copper (rectangular cross-section) |
Insulation | PTFE Polyethylene |
Outer sheath | PVC |
Connectors contacts material | Copper alloy |
Connectors contacts plating | Gold |
Cable diameter | Ø10mm |
Color | Black |
Length (m) |
Shielding |
Section (mm²) |
Connector |
Conductors material (Cable) |
Conductors Plating (Cable) |
