Il est réellement dommage que sur le descriptif il n'est pas précisé le diamètre des fiches qui ne sont pas du même que la plupart des fiches bananes.
Après modification tout est rentré dans l'ordre.
Beau produit.
Viablue SC-4 Silver-Series Jumper Bridges Sleeves crimped
These "jumpers" or "shunts" are used to connect the two channels of a two-wire terminal block.
The cable used is the Silver-plated ViaBlue SC-4
These cables are manufactured in Germany
The connectors are 24-carat plated crimp sleeves for better contact.
Length 15 cm
The length given relates to the cable without connectors
Included Qty: Set x4
Length (m) | 0.1 |
Shielding | NC |
Section (mm²) | N/A |
Connector | Banana |
Conductors material (Cable) | Copper |
Conductors Plating (Cable) | Silver |
Average votes 3.0 / 5 1 reviews | Why write products reviews ? You can share your feelings about products and help other people by sharing your experience |
Dario G.
