1877PHONO NOVA-SPK Bananas Speaker Cables Silver Plated PC-OCC Copper 3.31mm² 2.5m (Pair)
These 1877Phono Zavfino Nova-SPK banana speaker cables are positioned on a top-of-the-range cable segment, designed to offer exceptional performance thanks to flawless signal transmission. To do this, no design step is left to chance and the selected components are processed to provide their full potential.
4.9 / 5
By buying this product you get 38 loyalty points
Reference : 7406
389,00 €tax incl.
324,17 € tax excl.
Shipping date: 22-04-2025.
1877PHONO NOVA-SPK
Banana speaker cables PC-OCC Gold plated 3.31mm² 2.5m (Pair)
PC-OCC Copper & Silver Plating
The Nova-SPK integrates single-crystal PC-OCC Copper Litz conductors with a cross-section of 12AWG / 3.31mm². These ensure excellent audio signal transmission due to optimal conductivity. The Litz yarn structure considerably reduces the skin effect. These conductors also benefit from a silver plating to increase conductivity even further.
The conductors have a double dielectric isolation to drastically limit harmful interference to the audio signal and sound reproduction. In addition, the cable has two large EVA splitters to reduce vibration.
1877Phono Nova-SPK câbles d'enceintes Deep Cryo Treated
Deep Cryo Treated
This is a cryogenic treatment at two temperature levels, -186°C and -196°C, depending on the nature of the material used. This treatment optimizes the conductor crystals with the sole aim of providing the best possible transmission of the audio signal.
Ultra Sonic 7
After extrusion, Nova-SPK Copper goes through a thermal high voltage surface cleaning process, close to electrolysis and more efficient than cleaning with a conventional cleaning agent. The result is a very pure conductor and the extraction oils and surface heating residues are completely eliminated. This process also makes it possible to obtain a ready-to-use cable, already ground in and offering an optimal result from the first musical notes on a high-end HiFi system.
1877Phono Nova-SPK câbles d'enceintes traitement Ultra Sonic 7
Technical carateristics
SpEcifications
Product typeSpeakers cable
Length2.5m
ConnectorsBanana gold plated 24k"
Conductors materialsPC-OCC Copper (Litz wire)
Section12AWG (3.31mm2)
Conductors platingSilver
Conductors pin platingGold
InsulationDual dielectric
SheathPVC (105c)
Protection sheathBraided fiberglass
SplittersEVA (anti-vibrations)
Cable diameter17mm
Splitters diameter35.3mm
CoulorBlack, purple and silver
QuantitySold by pair
Length (m)2.5
ShieldingYes
Section (mm²)3.30
ConnectorBanana
11 reviews
quand même!
Testés fraichement hier, malgré avoir eu quelques expériences me prouvant l'efficacité de bons câbles, je suis toujours frileux dans ce domaine... j'ai pourtant pû clairement choisir entre deux coax, deux toslink, et là clairement c'est au dessus de mes Qed Silver XT Anniversary qui certes étaient un peu fatigués, le rendu était criard sur BW avec des aigus parfois insupportables! Là tout est plus cohérent, la scène est plus centré, je trouve ca assez fou, j'ai gagné légèrement en basse c'est pas dingue non plus, le fameux "silence" est là, et oui les aigus sont plus doux, saturent moins, le plaisir est là, forcément ca donne envie de toujours plus et c'est là que ca devient compliqué... vous le savez!
This review has been posted for 1877PHONO NOVA-SPK Bananas Speaker Cables Silver Plated PC-OCC Copper 3.31mm² 2.5m (Pair)
Superb cable
never thought a cable can make such a difference in particular at this price range, the sound has become more smooth an open as if there is less resistance. I would recommend this product, thank you
Impécâble
Très bon câble ; impressionnant.
Changement d'écran !
Ces câbles m'ont fait passer du 4/3 au 16/9, d'un LCD 46" à un écran 4K Oled 55". J'avais déjà un beau rendu, j'ai le cinéma scope maintenant.
Excellent rapport qualité prix
Ils relient désormais mon Atoll IN300 à mes Atohm GT1.
Je vais faire simple:
Excellent câbles, capables de se mesurer à de très bons câbles au double du prix.
Câbles HP très qualitatifs et surtout très homogènes:
Les aiguës ne sont jamais agressifs, les médiums sont très propres, et les graves sont toujours bien tenus, la contrebasse est un vrai régal...
Le service Audiophonics est toujours au top.
These 1877Phono Zavfino Nova-SPK  banana speaker cables  are positioned on a top-of-the-range cable segment, designed to offer...
