1877PHONO NOVA-SPK Bananas Speaker Cables Silver Plated PC-OCC Copper 3.31mm² 5m (Pair)
These 1877Phono Zavfino Nova-SPK banana speaker cables are positioned on a top-of-the-range cable segment, designed to offer exceptional performance thanks to flawless signal transmission. To do this, no design step is left to chance and the selected components are processed to provide their full potential.
By buying this product you get 63 loyalty points
Reference : 17440
639,00 €tax incl.
532,50 € tax excl.
Shipping date: 24-04-2025.
1877PHONO NOVA-SPK
Banana speaker cables PC-OCC Gold plated 3.31mm² 5m (Pair)
1877PHONO NOVA-SPK Bananas Speaker Cables Silver Plated PC-OCC Copper 3.31mm² 2.5m (Pair)
PC-OCC Copper & Silver Plating
The Nova-SPK integrates single-crystal PC-OCC Copper Litz conductors with a cross-section of 12AWG / 3.31mm². These ensure excellent audio signal transmission due to optimal conductivity. The Litz yarn structure considerably reduces the skin effect. These conductors also benefit from a silver plating to increase conductivity even further.
The conductors have a double dielectric isolation to drastically limit harmful interference to the audio signal and sound reproduction. In addition, the cable has two large EVA splitters to reduce vibration.
1877Phono Nova-SPK câbles d'enceintes Deep Cryo Treated
Deep Cryo Treated
This is a cryogenic treatment at two temperature levels, -186°C and -196°C, depending on the nature of the material used. This treatment optimizes the conductor crystals with the sole aim of providing the best possible transmission of the audio signal.
Ultra Sonic 7
After extrusion, Nova-SPK Copper goes through a thermal high voltage surface cleaning process, close to electrolysis and more efficient than cleaning with a conventional cleaning agent. The result is a very pure conductor and the extraction oils and surface heating residues are completely eliminated. This process also makes it possible to obtain a ready-to-use cable, already ground in and offering an optimal result from the first musical notes on a high-end HiFi system.
1877Phono Nova-SPK câbles d'enceintes traitement Ultra Sonic 7
Technical carateristics
SpEcifications
Product typeSpeakers cable
Length5m
ConnectorsBanana gold plated 24k"
Conductors materialsPC-OCC Copper (Litz wire)
Section12AWG (3.31mm2)
Conductors platingSilver
Conductors pin platingGold
InsulationDual dielectric
SheathPVC (105c)
Protection sheathBraided fiberglass
SplittersEVA (anti-vibrations)
Cable diameter17mm
Splitters diameter35.3mm
CoulorBlack, purple and silver
QuantitySold by pair
Length (m)5.0
ShieldingNC
Section (mm²)3.30
ConnectorBanana
These 1877Phono Zavfino Nova-SPK  banana speaker cables  are positioned on a top-of-the-range cable segment, designed to offer...
