By buying this product you get 63 loyalty points
Câbles Enceintes Fourches Cuivre PC-OCC Plaquage Argent 5m (La paire)
These 1877Phono Zavfino Nova-SPK fork speaker cables are positioned on a top-of-the-range cable segment, designed to offer exceptional performance thanks to flawless signal transmission. To do this, no design step is left to chance and the selected components are processed to provide their full potential.
The Nova-SPK integrates single-crystal PC-OCC Copper Litz conductors with a cross-section of 12AWG / 3.31mm². These ensure excellent audio signal transmission due to optimal conductivity. The Litz yarn structure considerably reduces the skin effect. These conductors also benefit from a silver plating to increase conductivity even further.
The conductors have a double dielectric isolation to drastically limit harmful interference to the audio signal and sound reproduction. In addition, the cable has two large EVA splitters to reduce vibration.
This is a cryogenic treatment at two temperature levels, -186°C and -196°C, depending on the nature of the material used. This treatment optimizes the conductor crystals with the sole aim of providing the best possible transmission of the audio signal.
After extrusion, Nova-SPK Copper goes through a thermal high voltage surface cleaning process, close to electrolysis and more efficient than cleaning with a conventional cleaning agent. The result is a very pure conductor and the extraction oils and surface heating residues are completely eliminated. This process also makes it possible to obtain a ready-to-use cable, already ground in and offering an optimal result from the first musical notes on a high-end HiFi system.
Product type | Speaker cables |
Length | 5m |
Connectors | Spades (5.8mm, 8mm, 9mm) |
Conductors material | PC-OCC Copper (Litz wire) |
Section | 12AWG (3.31mm²) |
Conductors plating | Silver |
Connectors plating | Gold |
Insulation | Dual dielectric |
Sheath | PVC (105C) |
Protection sheath | Braided fiberglass |
Splitters | EVA (anti-vibrations) |
Cable diameter | 17mm |
Splitters diameter | 35.3mm |
Quantity | Sold per pair |
Cable color | Black, purple and silver |
Length (m) | 5.0 |
Shielding | NC |
Section (mm²) | 3.30 |
Connector | Banana / Spade |
Conductors material (Cable) | Copper |
Conductors Plating (Cable) | Silver |
