1877PHONO PRIMA-OCC MK2 Loudspeakers cables Banana plugs 3.5m (a Pair)
By buying this product you get 84 loyalty points
Reference : 8553
849,00 €tax incl.
707,50 € tax excl.
Shipping date: 24-04-2025.
The PRIMA-OCC MK2 is an improved version of the NOVA-OCC with Higher cross-section conductors.
Cefinitely Both in high-end icts superb finish and in the choice of materials, it will allow you to very Significantly Improve one of the MOST significant links in your audio system.
Equipped with silver-plated PC-OCC copper conductors, it will bring out all the micro details of your favorite music.
ConductorOCC copper plated (CSC) 9AWG (6.6 mm²)
StructureType Litz wire
InsulationDual dielectric
SheathPVC (105c)
Protective shealthBraided glass fiber
Splittersanti vibration EVA
Outside diameter19.5mm
TerminationsBananas 24k gold plated "
ConditioningPair
Lenght3.5m
Length (m)3.6
ShieldingNC
Section (mm²)6.63
ConnectorBanana
3 reviews
OUTSTANDIG
Absolutely wonderful. Gives you all the details, colors, atmosphere and space you can dream at third cost of those very renamed brands. I am absolutely sold with this cable. My system is quite high level (CH Precision A1.5 + Holoaudio May DAC + Marten Mingus speakers), able to give all posible details of any record, and with this cable I can hear so many much more now than with my previous so famous super expensive Audioquest cable, that I can't believe it.
It takes about 60 hours of use to break through. In the beginning sounds very detailed, but constrained, a little Metallic, but after those 60-70 hours, its spacious, open, dynamic, brilliant, powerful, detailed, harmonic....
For this price, it's impossible to find a better speaker cable, anywhere, any brand.
This review has been posted for 1877PHONO PRIMA-OCC MK2 Loudspeakers cables Banana plugs 3.5m (a Pair)
RQP imprésionnant !!!
à moins de 400€ en longueur de 3.5 mètres c'est difficile de trouver mieux, le registre le plus surprenant étant les basses enfin plutôt la tenue de celles-ci, la scéne sonore globale est beaucoup plus ouverte aussi par rapport à des Cardas bi-cablés ou des WhyNot FLASH (début de gamme chez WhyNot)...Les terminaisons bananes que j'ai sur ces cables ne ressemblent pas par contre à celle que l'on peut voir sur les photos de votre site est-ce normal ou pas (perso c'est pas génant pour moi dans le sens ou ceux que j'ai reçu m'ont limite l'air plus qualitatif que ceux sur vos photos) ?
Du costaud
Ces câbles sont venus en remplacement de Nova qui étaient trop courts pour la nouvelle installation. Le niveau de finition et la robustesse sont sans reproche, les bananes verrouillables sont une sécurité appréciable et le look est sympa. A l'avenir je pense m'équiper en câble exclusivement chez Zavfino. L'association avec du Rotel et Bowers & Wilkins est parfaite (1590/804d3).
