1877PHONO PRIMA-OCC MK2 loudspeakers cables with banana 2.5m (Pair)
Reference : 7414
699,00 €tax incl.
582,50 € tax excl.
Shipping date: 28-03-2025.
The PRIMA-OCC MK2 is an improved version of the NOVA-OCC with Higher cross-section conductors.
Cefinitely Both in high-end icts superb finish and in the choice of materials, it will allow you to very Significantly Improve one of the MOST significant links in your audio system.
Equipped with silver-plated PC-OCC copper conductors, it will bring out all the micro details of your favorite music.
ConductorOCC copper plated (CSC) 9AWG (6.6 mm²)
StructureType Litz wire
InsulationDual dielectric
SheathPVC (105c)
Protective shealthBraided glass fiber
Splittersanti vibration EVA
Outside diameter19.5mm
TerminationsBananas 24k gold plated "
ConditioningPair
Lenght2.5m
Length (m)2.5
ShieldingYes
Section (mm²)6.63
ConnectorBanana
6 reviews
Killer cable
Beautifully full open ,sweet cable with solid bass,no part of the frequency spectrum is out of place,all presented in a cohesive whole,things appear out of the mix with astounding clarity,but unforced and naturally placed ,just outstanding quality....this occ cable is well made and very affordable when you consider what is on the market,what matters most is its musicality fast open clean clear warm and very addictive ,this cable just sounds right ,one word of caution do change the brass plugs for pure copper ones to get the very best ,i upgrade the banana plugs for the ramm audio Tellurium copper gold plated plugs and it just made a great cable even better....For me the search is over and now my pmc speakers sing freely with these cables .....highly recommended .Zavfino have achieved what they have set out to do with this cable GREAT STUFF.
 (3)
This review has been posted for 1877PHONO PRIMA-OCC MK2 loudspeakers cables with banana 2.5m (Pair)
Prima rules
I have lived with Kimber 8vs for 15 years now ,i have tried a fair few cables but always returned to the kimber kable this was because they had a good balance,now i have found a great cable ,these Prima-occ cables are the buisness....they cover all frequency extremes in balance,bass,midrange,treble all presented in a cohesive whole ,fast delivery from what seems like a black background,treble is sweet and you dont have to listen too hard for instruments jumping out of the mix ,the midrange is perfectly matched voices whether male or female they are delivered just as intended,bass is firm and full these cables have certainly made my PMC 25 26 sing ,Zavfino have achieved what they have set out to do with these cables and that is make music,its hard to say goodbye to my Kimbers but with the Prima in place its adios and thank you for years of service....Hello prima many more years to come,Great cable buy with confidence
On va faire bref ...... Pour le mélomane de la musique.
Mon installation :
CD 100 Atoll, ampli ATOLL IN300, Focal aria 948 .
Comme indique le nom du produit PHONO voilà un câble qui va sortir un son chaud celui du vinyle ou comme à l'époque la touche sur votre autoradio fonction LOUDNESS si cela vous parle plus .
Les Aigus sont doux, médium équilibrés , bases dynamiques et profondes . La spatialisation , l' image 3 D est superbe sans exagération , la restitution de la musique est très détaillée . Le son " pousse " sans casser les oreilles à haut niveau sonore.
Si vous écoutez du jazz, reggea , disco , funk, latino ,house , tendance électronique le 1877 phono est pour vous !!!!
Classique, pop rock , variété ... Allez plutôt vous orienter vers un autre produit que Audiophonics vous conseillera .
excellents câbles
J'ai acheté ces câbles pour remplacer ceux de ma chaîne Hi-Fi qui sont dégradés extérieurement, certainement par des produits détergents. Mon ensemble Hi-Fi est composé d'un ampli Jadis Orchestra Référence, un CD Audio Note et une paire d'enceintes Lintra Silhouette. Les câbles m'avaient été offert par le vendeur. Ce sont des HMS.
Je les ai remplacé par ces nouveaux et j'en suis très satisfait aussi bien sur la qualité d'écoute que sur le prix qui est 3 à 4 fois inférieur à ceux des HMS.
En conclusion, je recommande Audiophonics sans hésitations
Des boas de l'audio
Ces très gros et lourds câbles sont vraiment à essayer tant ils restituent le son sans avoir de points faibles, hormis leur poids.
Il faut bien prendre en compte leur taille, on ne s'y fait pas avec la photo mais il sont bien costauds et peu flexibles, donc mieux avoir des bons borniers pour les fixer solidement.
J'insiste sur ce point simplement pour éviter la surprise au déballage, du reste, le gros avantage du câble comparé à d'autres notamment un type 4 occ sans bananes est d'avoir une écoute plus élargies, pas simplement au niveau des détails qui passent tous dans les enceintes mais surtout au niveau du message musical : on a l'impression qu'il était auparavant écourté et que toute les notes ne sont plus découpés.
Les aigus, medium et graves sont vraiment très beaux à écouter, à noter que le son est plus réaliste, et j'ai noter une présence moins puissante des graves même après rodage. Simplement, vu la beauté des sons développés, très proche d'un vrai enregistrement, je pense que les anciens câbles étaient plus dopés dans le graves, nuisant à la fidélité.
Sincèrement, ces câbles sont en un sens un problème : une fois mis en place, en les laissant se roder, la course aux câbles de hauts parleurs prends fin. Ils sont cependant très méchant avec les systèmes qui n'ont pas un minimum de qualité, des Klipsch RB-81 mk II montraient très vite leurs limites alors qu'elles sont décemment placées dans les productions actuelles.
Ce sont des câbles pour utiliser la totalité de votre système et tirer le son qu'il peut reproduire du fin fond de ses entrailles électroniques vers vos oreilles.
Au passage : le service audiophonic est une perle rare.
 (4)
