NEOTECH NES-3001 Gold Plated UP-OCC Copper Speaker Cable 17AWG Ø15mm 2m (A pair)
The Neotech NES-3001 joins the brand's wide range of high-end speaker cables. Its unique design allows it to participate in the reproduction of both warm and deep sound, thanks in particular to the effective insulation of PTFE conductors.
By buying this product you get 149 loyalty points
Reference : 13742
1 499,00 €tax incl.
1 249,17 € tax excl.
Neotech NES-3001
Neotech NES-3001 Câble Haut-Parleur Cuivre UP-OCC 17AWG Ø15mm
The cable has no less than 16 insulated conductors: 6 red, 6 black and 4 transparent. Each conductor, made of UP-OCC single crystal Copper, has an outer diameter of Ø2.1mm and an inner diameter of Ø1.1mm for a cross-section of 17AWG (1.04mm²) per conductor for a total cross-section of 8AWG (8.37mm²). These individually insulated conductors are then braided around a PVC core and covered with a braided Nylon sheath.
These conductors are made of UP-OCC single crystal Copper, specially developed by Professor Ohno. This ensures an extremely high purity of 99.99998%. It thus offers maximum signal conductivity for high-precision sound reproduction.
The NES-3001 ends on either side with two gold plated and oxidation resistant forks, ensuring a firm hold of the connector to the terminals.
Comparaison Cuivre UP-OCC et Cuive OFC
Product typeSpeaker cable
Length2m
Number of conductors16
Conductors materialUP-OCC Copper
External diameter / conductorØ2.1mm
Internal diameter / conductorØ1.1mm
Section / conductor17AWG (1.04mm²)
ConnectorsSpades
Connectors platingGold
Total external diameter15mm
Internal sheathPVC
Conductors insulationPTFE
External sheathBraided Nylon
Delivered in pairsYes
Certificat Cuivre UP-OCC Professeur Ohno
Length (m)
  • 2.0
Shielding
  • NC
Section (mm²)
  • 1.04
Connector
  • Spade
Conductors material (Cable)
  • Copper
Conductors Plating (Cable)
  • None
The Neotech NES-3001 joins the brand's wide range of high-end speaker cables. Its unique design allows it to participate in the reproduction...
