By buying this product you get 59 loyalty points
This high quality HP cable is assembled with Oyaide SPSL Forks silver plated and platinum designed on CNC machine of precision extruded on round bars.
The twin screw clamping system of the SPSL forks ensures precision mechanical strength.
The Oyaide 3000 Y speaker cable has a double plating Silver and Platinum ensures stability of the electrical characteristics in the optimal time. Braiding type 3E plus is designed by the Japanese company Sanshu Technology of medical origin offering superior conductivity to conventional coaxial braiding systems.
The ACROSS 3000 Y is developed for music lovers looking for a very neutral sound over the bandwidth, musical, a perfect balance between definition and a warm timbre.
The Cross System Stabyliser system allows the least possible contact between the conductor and the insulation for increased mechanical stability.
Oyaide manufactures each cable in the same way, with optimized engineering solutions applied to materials and manufacturing processes, complemented by meticulous craftsmanship.
Characteristics :
Length (m) | 2.5 |
Shielding | NC |
Section (mm²) | N/A |
Connector | Spade |
Conductors material (Cable) | Copper |
Conductors Plating (Cable) | None |
