TRIANGLE SYMPHONIE SYS25A Speaker Cables OFHC Copper Silver Plating 2.5m (Pair)
The Triangle Symphonie speaker cable has been designed to ensure excellent signal transmission quality, thanks to the use of high quality materials. It uses large conductors made of 99.99% pure OFHC copper, ensuring optimal electrical conductivity.
Reference : 15996
149,00 €tax incl.
124,17 € tax excl.
Shipping date: 24-04-2025.
Triangle Symphonie SYS25A
Triangle Symphonie Câbles d'Enceintes Cuivre OFHC Plaquage Argent 2.5m
The Triangle Symphonie speaker cable has been designed to ensure excellent signal transmission quality, thanks to the use of high quality materials. It uses large conductors made of 99.99% pure OFHC copper, ensuring optimal electrical conductivity. Each conductor is protected by a double insulating polyvinyl chloride sheath separated by an antistatic foil, in order to eliminate any distortion and electromagnetic interference. The cable is finally covered with a fabric sheath.
Each end of the cable uses BP400 Triangle banana plugs, allowing for a quick and reliable connection to your speakers. These connectors are silver plated to maintain high conductivity.
Product typeSpeaker cables
Length2.5m
Conductors section2.5mm²
Conductors materialOFHC copper (Purity: 99.999%)
InsulationDouble PVC sheath separated by an antistatic sheet
Cover sheathFabric
Connectors contacts platingSilver
Connectors body materialAnodized aluminum
QuantityPair
Length (m)2.5
ShieldingNC
Section (mm²)2.5
ConnectorBanana
Agréablement étonnant !
Dubitatif quant à la nécessité de changer mes bon vieux et basics câbles d'enceintes.
J'en reconnait l'utilité maintenant avec ces "câbles triangle symphonie".
Je n'ai pas changé d'enceintes (des triangles) et pourtant !
Plus de détails dans tous les registres , moins d'agressivité et plus de finesse dans les aigus, des médiums enchanteurs et des basses plus profondes et tendues.
Je redécouvre des morceaux de musique avec des détails non perçus auparavant et pensait que mes enceintes donnaient déjà leur maximum, il n'en était rien.
Câble de qualité de fabrication reçu rapidement par Audiophonics.
Rien à redire.
This review has been posted for TRIANGLE SYMPHONIE SYS25A Speaker Cables OFHC Copper Silver Plating 2.5m (Pair)
The Triangle Symphonie speaker cable has been designed to ensure excellent signal transmission quality, thanks to the use of high quality...
