TRIANGLE SYMPHONIE SYS30A Speaker Cables OFHC Copper Silver Plating 3m (Pair)
The Triangle Symphonie speaker cable has been designed to ensure excellent signal transmission quality, thanks to the use of high quality materials. It uses large conductors made of 99.99% pure OFHC copper, ensuring optimal electrical conductivity.
Reference : 15997
169,00 €tax incl.
140,83 € tax excl.
Triangle Symphonie SYS30A
Triangle Symphonie Câbles d'Enceintes Cuivre OFHC Plaquage Argent 2.5m
The Triangle Symphonie speaker cable has been designed to ensure excellent signal transmission quality, thanks to the use of high quality materials. It uses large conductors made of 99.99% pure OFHC copper, ensuring optimal electrical conductivity. Each conductor is protected by a double insulating polyvinyl chloride sheath separated by an antistatic foil, in order to eliminate any distortion and electromagnetic interference. The cable is finally covered with a fabric sheath.
Each end of the cable uses BP400 Triangle banana plugs, allowing for a quick and reliable connection to your speakers. These connectors are silver plated to maintain high conductivity.
Product typeSpeaker cables
Length3m
Conductors section2.5mm²
Conductors materialOFHC copper (Purity: 99.999%)
InsulationDouble PVC sheath separated by an antistatic sheet
Cover sheathFabric
Connectors contacts platingSilver
Connectors body materialAnodized aluminum
QuantityPair
Length (m)3.0
ShieldingNC
Section (mm²)2.5
ConnectorBanana
The Triangle Symphonie speaker cable has been designed to ensure excellent signal transmission quality, thanks to the use of high quality...
