Speaker Cables OFHC Copper Silver Plating 3m
The Triangle Symphonie speaker cable has been designed to ensure excellent signal transmission quality, thanks to the use of high quality materials. It uses large conductors made of 99.99% pure OFHC copper, ensuring optimal electrical conductivity. Each conductor is protected by a double insulating polyvinyl chloride sheath separated by an antistatic foil, in order to eliminate any distortion and electromagnetic interference. The cable is finally covered with a fabric sheath.
Each end of the cable uses BP400 Triangle banana plugs, allowing for a quick and reliable connection to your speakers. These connectors are silver plated to maintain high conductivity.
Product type | Speaker cables |
Length | 3m |
Conductors section | 2.5mm² |
Conductors material | OFHC copper (Purity: 99.999%) |
Insulation | Double PVC sheath separated by an antistatic sheet |
Cover sheath | Fabric |
Connectors contacts plating | Silver |
Connectors body material | Anodized aluminum |
Quantity | Pair |
Length (m) | 3.0 |
Shielding | NC |
Section (mm²) | 2.5 |
Connector | Banana |
Conductors material (Cable) | Copper |
Conductors Plating (Cable) | None |
