VIABLUE SC-4 Speaker Cables Silver Plated 1.5m (Pair)
20%
ViaBlue ™ SC-4 Silver-Series Speaker Cables have silver-plated strands for the treble range and tin-plated strands for powerful playback of the bass range. The cables are factory-installed ready-made with ViaBlue ™ T8 banana plugs, which have 24 carat genuine-gilded bronze contacts. Technically, all the frequency ranges are cleanly and realistically represented and reproduced in a linear fashion.
Reduced price!
Reference : 103
Limited special offer
399,99 €tax incl.
-20%
319,99 €tax incl.
266,66 € tax excl.
Shipping date: 22-04-2025.
Definition. Details. Living music.
High-End quality. Salient Design. ViaBlue ™ Cobra.
SC-4 speaker cables have a transparent and three-dimensional acoustics and a brilliant, airy quality in the high range. Clean lows and basses homogeneously round the acoustic pattern. Technically, all the frequency ranges are cleanly and realistically represented and reproduced in a linear fashion.
Silver plating for more brilliance.
Through the combination of silver-plated and tin-plated leads, the finest details and brilliance of the treble range as well as the lower frequency signals of the bass range are fully carried and reproduced through the attached speakers.
The SC-4 speaker cables are braided with the ViaBlue ™ Cobra protective sleeve, which also displays high-end speaker cables.
The splitters typically used with ViaBlue ™ cables protect the cable ends from snapping off and, at the same time, provide a professional, thought out routing of the single leads.
The 6th sense - T8 connectors on the SC-4 Silver-Series.
SC-4 Silver Series speaker cables are supplied ready-made with ViaBlue ™ T8 banana plugs. ViaBlue ™ T8 banana plug have contact pins from bronze that is 24 carat gold plated. The plugs are made from aluminum. The contacts can be exchanged by the optionally available spades and flexible pins easily.
Viablue SC-4 review by HiFi-Choice
" The beautifully made SC-4 excels in delivering a refined sound across a wide range of music "
Characteristics :
  • Sectional conductor 4 x 4mm² (224 x 0.15mm)
  • PVC Insulation
  • Tinned Lead Resistance: 4.6mOhm / m
  • Resistance of the conductor plated Silver: 4.4mOhm / m
  • Capacity: 136pF / m
  • Inductance: 0.63μH / m
All ViaBlue ™ cables are manufactured in Germany and are made by hand.
Length (m)1.5
ShieldingNC
Section (mm²)4.00
ConnectorBanana
ViaBlue ™ SC-4 Silver-Series Speaker Cables have silver-plated strands for the treble range and tin-plated strands for powerful playback...
