VIABLUE SC-6 AIR BAN Silver Plated OFC Copper Speaker Cable with Banana Plugs 3m (Pair)
Viablue SC-6 cables feature a high-end design, ensuring maximum conductivity for an optimal audio experience. Each cable includes 6 insulated OFC Copper conductors placed in a circle around a central air tube and separated by other air tubes, providing a higher level of insulation.
4.0 / 5
By buying this product you get 139 loyalty points
Reference : 13775
1 399,99 €tax incl.
1 166,66 € tax excl.
Shipping date: 16-04-2025.
Viablue SC-6 AIR
Viablue SC-6 Câbles d'Enceintes Bananes Cuivre OFC Plaqué Argent 3m (La Paire)
Viablue SC-6 AIR cables feature a high-end design, ensuring maximum conductivity for an optimal audio experience. Each cable includes 6 insulated conductors placed in a circle around a central air tube and separated by other air tubes, providing a higher level of insulation. This particular structure allows a physical separation of the conductors and therefore eliminates unwanted electrical capacity in the cable. The air tubes also prevent inductance and harmful magnetic fields.
Of the 6 conductors, two are made of Silver plated OFC Copper for precise high frequency reproduction, two others of tinned OFC Copper for detailed midrange and finally the last two are made of pure OFC Copper for deep bass. Each conductor also includes a central air tube.
Viablue SC-6 AIR: Banana plugs
Viablue SC-6 cables have Viablue T8 banana plugs, allowing quick and easy connection. These 24k gold plated plugs use a design that ensures maximum contact with your terminals.
OFC Copper
The OFC Copper used in Viablue cables has an extremely high purity, with an oxygen level of 0.001% maximum. This material provides excellent conductivity.
Air Pipes
Viablue SC-6 cables incorporate flexible and air-filled Silicone tubes. They provide optimal isolation and physical separation of conductors and frequencies.
Viablue Splitters
These splitters allow intelligent and precise cable organization while protecting cables when mechanical stresses are applied.
Diapason d'Or for the Viablue SC-6
" At the prices at which these cables are offered, the gain is significant, indisputable and totally justified. A nice discovery of a know-how from the other side of the Rhine. "
Diapason d'Or pour le Viablue SC-6
Product typeSpeaker cable
Length3m
Cable typeSingle-Wiring
Connectors24k Gold plated banana plugs (Viablue T6s)
Number of conductors6
Conductors material2x Pure OFC Copper
2x Silver Plated OFC Copper
2x Tinned OFC Copper
Insulation10x Air tubes
Cable diameterØ27mm
Splitters diameterØ36mm
Capacity (conductor to conductor)91pF/m
63pF/m
QuantitySold per pair
Length (m)3.0
ShieldingNC
Section (mm²)15.00
ConnectorBanana
Très bien
Après 4 mois de test je suis satisfait de ces câbles HP, j'avais auparavant les SC-4...qui étaient très bien et avec plus de raffinement plus de détail...mais j'ai quand même attendu un rodage..J'ai corrigé le manque de détail par des tubes pré-ampli plus raffinés..Je garde les SC-6 et vendu les SC-4 ..je les recommandes ...Merci a Audiophonics pour la rapidité et le délai de livraison !
This review has been posted for VIABLUE SC-6 AIR BAN Silver Plated OFC Copper Speaker Cable with Banana Plugs 3m (Pair)
Viablue SC-6 cables feature a high-end design, ensuring maximum conductivity for an optimal audio experience. Each cable includes 6 insulated OFC...
