-Gold Rush cable series-
The cable DIN 5 to RCA 1877 PHONO Gold Rush represents today the top-of-the-range and all the know-how of the Canadian brand. This dedicated cable for premium phono player has a selection of the finest components for music only.
Featuring a 24K gold-plated pure copper strand with 99.9998% pure silver multicore wires with PC-OCC treatment, this cable uses state-of-the-art materials in a design, a structure specific to PHONO 1877.
The Gold Rush series is the result of continuous work and research on dielectrics and microdischarge interactions between each insulator. The Gold Rush series features PTFE sheaths coupled with a Graphene polymer encased in a silicone and fiberglass package that eliminates any electrostatic and vibratory effects. Each cable is shielded with a silver-coated aluminium mylar screen and finished with an R Flex sheath that resists temperatures of 105°.
DEEP CRYO TREATMENT
All the wires and conductors used in the production of this Phono DIN 5 cable go through a cold lowering treatment before the insulation extrusion on the conductive material in order to tighten the molecules by cryogenics. 1877 Phono goes further than the majority of cable manufacturers who carry out a cold operation at different temperatures depending on the material to be treated, making up each part of the cable.
High level 24 karat connectic PTFE contact series
The Gold Rush series has a series of special DIN 5 connectors in carbon body with PTFE insulation using the 1877 Phono "anti-stress" clamping process for perfect contact quality. RCA connectors are among the best on the market with the famous ZXP 5G series with 24 karat gold-plated OCC pure copper center pin.
1877 PHONO currently supplies more than a dozen of the most prestigious designers of arms for vinyl turntables.
Technicals caracteristics
SpEcifications |
Cable type : | Stereo Phono 90° TAD type DIN 5 to RCA X2 |
Input | DIN 5-pin gold-plated 24K gold plated high quality insulating contact PTFE carbon body |
Output | RCA X2 Gold plated 24K Copper OCC pins |
Insulator | PTFE with Graphene, glass Fiber, Silicon on PVC R-FLEX sleeve |
Conductor material | Monobrin copper 24K Gold plated 24K PC OCC central section + pure silver PC OCC multi-stranded OCC multicore |
Ground connector | Copper SP OFC with copper clamp OCC 24K |
Surface treatment | DEEP Cryo ( -186° et -196° ) |
External screen | Silver aluminum mylar silver foil sheets |
longueur | 1M50 |
