1877PHONO GOLD RUSH ST AU/AG DIN to RCA Cable Pure Silver Plated PC-OCC Copper 1m50
The 1877 PHONO Gold Rush DIN 5 to RCA series includes all the technological refinements that make it a very high level analogue cable. This dedicated Phono arm cable is specially designed for demanding 33 rpm enthusiasts who want the best for their vinyl turntables.
Strengths:
  • Hybrid topology copper PC OCC 24K Gold plated and pure silver PC OCC
  • Low Discharge Insulators PTFE, Silicone, Fiberglass and Graphene
  • 24K gold-plated OCC pure central pin conductor RCA connectors
By buying this product you get 101 loyalty points
Reference : 12503
1 019,00 €tax incl.
849,17 € tax excl.
Shipping date: 24-04-2025.
- Gold Rush cable series -
1877phono-gold-rush-cable-phono-pc-occ-a
The cable DIN 5 to RCA 1877 PHONO Gold Rush represents today the top-of-the-range and all the know-how of the Canadian brand. This dedicated cable for premium phono player has a selection of the finest components for music only.
Featuring a 24K gold-plated pure copper strand with 99.9998% pure silver multicore wires with PC-OCC treatment, this cable uses state-of-the-art materials in a design, a structure specific to PHONO 1877.
The Gold Rush series is the result of continuous work and research on dielectrics and microdischarge interactions between each insulator. The Gold Rush series features PTFE sheaths coupled with a Graphene polymer encased in a silicone and fiberglass package that eliminates any electrostatic and vibratory effects. Each cable is shielded with a silver-coated aluminium mylar screen and finished with an R Flex sheath that resists temperatures of 105°.
DEEP CRYO TREATMENT
All the wires and conductors used in the production of this Phono DIN 5 cable go through a cold lowering treatment before the insulation extrusion on the conductive material in order to tighten the molecules by cryogenics. 1877 Phono goes further than the majority of cable manufacturers who carry out a cold operation at different temperatures depending on the material to be treated, making up each part of the cable.
High level 24 karat connectic PTFE contact series
The Gold Rush series has a series of special DIN 5 connectors in carbon body with PTFE insulation using the 1877 Phono "anti-stress" clamping process for perfect contact quality. RCA connectors are among the best on the market with the famous ZXP 5G series with 24 karat gold-plated OCC pure copper center pin.
1877 PHONO currently supplies more than a dozen of the most prestigious designers of arms for vinyl turntables.
Technicals caracteristics
SpEcifications
Cable type :Stereo Phono straight DIN 5 to RCA X2
InputDIN 5-pin gold-plated 24K gold plated high quality insulating contact PTFE carbon body
OutputRCA X2 Gold plated 24K Copper OCC pins
InsulatorPTFE with Graphene, glass Fiber, Silicon on PVC R-FLEX sleeve
Conductor materialMonobrin copper 24K Gold plated 24K PC OCC central section + pure silver PC OCC multi-stranded OCC multicore
Ground connector Copper SP OFC with copper clamp OCC 24K
Surface treatmentDEEP Cryo ( -186° et -196° )
External screenSilver aluminum mylar silver foil sheets
Length1m50
Length (m)1.5
ShieldingYes
Section (mm²)N/A
ConnectorRCA
ConnectorDIN
Conductors Plating (Cable)Gold
1877Phono Gold Rush
I changed my Nordost Frey 2 phono cable with this 1877 Gold Rush. Everythings go better with this cable! More definition, more air, voices are more natural!. Great choice!!!!
This review has been posted for 1877PHONO GOLD RUSH ST AU/AG DIN to RCA Cable Pure Silver Plated PC-OCC Copper 1m50
The 1877 PHONO Gold Rush DIN 5 to RCA series includes all the technological refinements that make it a very high level analogue cable. This...
