By buying this product you get 52 loyalty points
The "HIGHLANDS" cable from the 1877 PHONO brand makes it possible to connect your 5-pin connector to a Phono preamplifier equipped with RCA * jacks.
Resolutely Audiophile in its design, it is especially useful for connecting old record players to our modern equipment, leaving them an additional chance to amaze us by their inimitable analog sound.
Sat the top of the 1877 PHONO line, the HIGHLANDS is distinguished by the use of 4 Pure Silver conductors with an individual diameter of 0.40mm, insulated with a Dupont Teflon®-FEP thermoplastic film.
lass = "lineText"> This second material, of French design, is renowned throughout the world for its excellent chemical resistance, its exceptional electrical properties and its incredible thermal resistance (-240 to + 205 ° C). In addition, Teflon® FEP is a proven flame retardant product, which earned it an ASTM D-3418 certification.
neText ">This first insulation is backed up by a spiral-coated copper screen that is enclosed in an Aluminum / Mylar strip to improve the immunity of conductors against radio interference (RFI) and electromagnetic interference (EMI).Life2 individual PVC sheaths designed to reinforce the "physical" protection of conductors while ensuring flexibility and flexibility for the cable in itsthen a double antistatic layer of PET (Polyethylene Terephthalate).
The black PVC outer sheath provides greater resistance to the harshness of the outside world. It is covered with a superb black and green nylon sheath which, with the solid beech partition box, gives the HIGHLANDS an inimitable cachet.
Thees Connectors also show the manufacturer's zeal, and its propensity to always use what's best: Thus the 5-pin DIN plug consists of non-magnetic copper plated with 24k fine gold and insulated Teflon , excuse the bit ...
The RsCA are not to be outdone and also benefit from a 24k Gold coating and Teflon insulation. Finally, it should be noted that each bond is made using a solder containing 5% of silver.
*NOTE :This cable does not allow to connect a turntable to a conventional line input (CD, TAPE, AUX ...). In order to operate, it requires an input on RCA sockets of higher sensitivity, generally accompanied by a grounding, and leading to a correction filter conforming to the RIAA standard. This type of input is generally labeled "PHONO" or "TURNTABLE" on integrated preamplifiers and amplifiers.Specifications:
Length (m) | 1.2 |
Shielding | Yes |
Section (mm²) | N/A |
Connector | RCA |
Connector | DIN |
Conductors material (Cable) | Copper |
Conductors Plating (Cable) | None |
