1877PHONO THE SPIRIT GR Phono DIN Male Cable GRACE - 2 RCA Black 1.5m
Reference : 5517
125,00 €tax incl.
104,17 € tax excl.
The cable "THE SPIRIT"of the Canadian brand1877 PHONOallows you to connect your GRACE type reading arm with connector5 Pinson a Phono preamplifier with RCA plugs *.
Resolutely Audiophile in its design, it is especially useful for connecting old record players to our modern equipment, leaving them an additional chance to amaze us by their inimitable analog sound.
D'a rare elegance with its black nylon sheath streaked in white and its satin-like connectors, the SPIRIT testifies to the love of its designers for beautiful things, whether visual or auditory.
MIt also testifies to the seriousness of their approach on the technical considerations: Thus the DIN and RCA plated with fine gold 24k andTeflon insulated , while each link is made with the aid of welding containing 5% silver.
The cable itself encloses 4 copper conductors OFHC silver plated section 0.40mm², surrounded by shielded copper braid, itself covered with a protective anti-static PET layer(Polyethylene Terephthalate).
*NOTE :This cable does not allow to connect a turntable to a conventional line input (CD, TAPE, AUX ...).In order to operate, it requires an input on RCA sockets of higher sensitivity, generally accompanied by a grounding, and leading to a correction filter conforming to the RIAA standard. This type of input is generally labeled "PHONO" or "TURNTABLE" on integrated preamplifiers and amplifiers.
Specifications:
  • Number of Drivers: 4
  • Composition of Conductors: OFHC Copper Plated Silver Section 0.40mm²
  • Input: DIN Male Plug 5 Pin Gold Plated 24k & Isolated Teflon
  • Output: 2 RCA Plugs + 24k Gold Plated Ground & Isolated Teflon
  • Shielding: Copper + Insulation Sheath PET (Polyethylene Terephthalate)
  • Total Cable Length: 1.50m
  • Finish: Black & White Nylon Sheath
https://www.audiophonics.fr/images2/5517/5517_1877_dinmale_5.jpg
https://www.audiophonics.fr/images2/5517/5517_1877_dinmale_1.jpg
https://www.audiophonics.fr/images2/5517/5517_1877_dinmale_2.jpg
https://www.audiophonics.fr/images2/5517/5517_1877_dinmale_3.jpg
https://www.audiophonics.fr/images2/5517/5517_1877_dinmale_4.jpg
Length (m)1.5
ShieldingYes
Section (mm²)0.40
ConnectorRCA
ConnectorDIN
excellent produit
Le changement du câble de ma platine s'est fait sans aucun problème ou ajustement..
La qualité de la connectique est excellente.
A la première écoute, je pense avoir gagné en définition et en étendu dans le haut du registre .
This review has been posted for 1877PHONO THE SPIRIT GR Phono DIN Male Cable GRACE - 2 RCA Black 1.5m
