1877PHONO THE SPIRIT MKII STBX Phono adapter DIN 5 pin - 2 RCA 0.45m
Reference : 11790
138,00 €tax incl.
115,00 € tax excl.
The adapter case "THE SPIRIT MKII" of the brand 1877 PHONO is the revisited version of the first "SPIRIT" of the name. This "adapter" cable allows you to connect your 5-pin connector to a Phono preamplifier with RCA jacks *.
Resolutely Audiophile in its design, it is especially useful for connecting old record players to our modern equipment, leaving them an additional chance to amaze us by their inimitable analog sound.
Of rare elegance in its formwork in real beech wood, the SPIRIT testifies of the love of its designers for beautiful things, whether visual or auditory.
But it also demonstrates the seriousness of their approach on technical considerations: Thus the DIN and RCA sockets are plated with fine gold 24k and isolated Teflon, while each internal link is made with the help of solder containing 5% silver.
Theit also deserves attention: it encloses within it 4 conductors of silver-plated OFHC copper of section 0.40mm², surrounded by braided copper shielding, itself covered with a protective layer anti-static PET ( PolyethyTerephthalate ).
*NOTE :This interface does not allow to connect a turntable to a conventional line input (CD, TAPE, AUX ...). To work, it requires an inpute on RCA sockets of higher sensitivity, usually accompanied by a grounding, and leading to a correction filter in accordance with the RIAA standard. This type of input is generally labeled "PHONO" or "TURNTABLE" on integrated preamplifiers and amplifiers.
Specifications:
  • Number of Drivers: 4
  • Composition of Conductors: OFHC Copper Plated Silver Section 0.40mm²
  • Input: DIN 5 Pin Gold Plated 24k Plug & Insulated Teflon
  • Output: 2 RCA Plugs + 24k Gold Plated Ground & Isolated Teflon
  • Shielding: Copper + Insulation Sheath PET (Polyethylene Terephthalate)
  • Total Cable Length: 0.45m
  • Finish: Genuine Beech Wood Formwork
  • Design and design: In CANADA
1877PHONO MKII Câble Phono DIN RCA
Length (m)0.4
Section (mm²)0.40
ConnectorRCA
ConnectorDIN
